Re: 70 cuda, fuel vapor line kit?
[Re: mopar mike]
#643885
03/19/10 09:21 AM
03/19/10 09:21 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Mike, Mount the line in the trunk with the bend following up the outside of the pinch weld of the wheel house. If you look under the car you will see that the front line has a bend to it which just hangs open in the frame rail. The rear of the two lines will have about a 2" piece of hose connecting to an additional "S" shapped line that goes to the single nipple off the gas take. There is also a short piece of hose between them. Sounds like your missing the correct "S" line that goes across under the muffler heat shield to the tank. The "S" line lays in the same oval slot the open line is in. Bob at Fine Lines (330-335-5000) has the right line kit you need if yours is not right and he also has the special clip I supplied him. The special clip holds the vaper line tight to the pinch weld in the trunk to keep the line from rattling. Hope that helps you Mike. Michael C. Ross - Owner B/E & A Restoration Parts, Inc. www.beaparts.com330-725-3990
[Re: HEMICUDA]
#643886
03/19/10 11:11 AM
03/19/10 11:11 AM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Hi Guys, I searched for the old thread but it's been a few years and it's not coming up so I'll repost the pics.....First pic is the rubber tank union with the keystone clamp and the "S" shaped piece through the frame... ....Next pic shows the outer trunk extension with the rubber trunk floor plugs...Small tube has the vapor routed into the trunk compartment loop...Bigger diameter line is the vapor end which exits into the frame...If you overfill the tank it will eventually spill fuel into the frame,out the hole and it will look like mine... ... My trunk floor was replaced so your vent lines won't go through the tab in the pic{it should be further back the seam}... ...Here's a shot of the trunk hardware... ... ....And lastely a close-up of the fenderwell clip... ....These pics should point you in the right direction !!! ....Colin
[Re: screamindriver]
#643887
03/19/10 12:58 PM
03/19/10 12:58 PM
HEMICUDA
Medina, Ohio
Good catch Colin.
