torque for UCA camber/caster adjuster bolts? #64322
05/26/08 11:40 PM
05/26/08 11:40 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
The title says it all, what should the two bolts on the upper control arm be torqued to? Just finished an alignment and want to make sure they are torqued right..
Re: torque for UCA camber/caster adjuster bolts? [Re: Exit1965] #64323
05/27/08 02:55 PM
05/27/08 02:55 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Re: torque for UCA camber/caster adjuster bolts? [Re: Exit1965] #64324
05/27/08 02:59 PM
05/27/08 02:59 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
65 foot pounds
Re: torque for UCA camber/caster adjuster bolts? [Re: Exit1965] #64325
05/27/08 03:03 PM
05/27/08 03:03 PM
Kirkland, Washington
Pacnorthcuda Offline
and a tip: If you matchmark the washers and their respective plates that they ride in with two dots (paint or felt pen) you will always be able to tell if something slipped. The rears (side closest to the firewall) are hard to see--I had to do those with a mirror, but now if I am ever in doubt I can check to make sure everything is where its supposed to be.
