In my quest to find a dual quad drop down base for an Dual Quad edelbrock setup, I am coming up dry but having to modify things.
So the thought is to take two drop down bases, cut 1/3 of the drop down base and filter cover. Mount it on the carbs and then lay in strips of sheet metal and make it complete to lay down some fiberglass and make it myself.
My question is.....What is the overall length, width, and height of a 6-pack air filter so I know how to map out the air cleaner bases. To see if it will work.
