Demon Body dimensions ? #641876
03/16/10 02:51 PM
03/16/10 02:51 PM
Arlington, Tx.
BJS racing Offline OP
Arlington, Tx.
Getting ready to start more of the chassis work on the Demon here in the next week or two now that I have a garage of my own. My problem is that I don't remember what the rocker seam to rocker seam dimensions are for a demon or a duster or dart. If anyone can let me know that would be great. Once I have that then I can rough mount the body and start on the main hoop and forward bars. Thanks again to all my friends here.
Jason
Back in the swing of things at Painless again! Great to be back!
Re: Demon Body dimensions ? [Re: BJS racing] #641877
03/16/10 02:59 PM
03/16/10 02:59 PM
Arlington, Tx.
Arlington, Tx.
And if any of you chassis guys out there could possibly give me some advise on how to bolt the body to the chassis I would greatly appreciate it. Ron you out there?
Re: Demon Body dimensions ? [Re: BJS racing] #641878
03/16/10 03:15 PM
03/16/10 03:15 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Weld that thing on there.
Re: Demon Body dimensions ? [Re: blown572dart] #641879
03/16/10 03:29 PM
03/16/10 03:29 PM
Arlington, Tx.
Arlington, Tx.
Bite it pinky! I actually have reasons for why I want to be able to remove the body. I should have just bought your chassis from the first go around. It would have worked in my car.
Re: Demon Body dimensions ? [Re: BJS racing] #641880
03/16/10 03:40 PM
03/16/10 03:40 PM
Orlando Florida
Orlando Florida
CALL MIKE AND STOP
Re: Demon Body dimensions ? [Re: BJS racing] #641881
03/16/10 03:43 PM
03/16/10 03:43 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Make 2x3 nut plates by drilling holes a little bigger than 3/8's...one on each side of where an 1 5/8 tube could land....weld 3/8 nuts to the back side....then drill holes big enough for the nuts to go inside of on your rocker panels...weld plates to rocker panels....wled matching plates to ends of tubes that tie into rocker panels....easy....quick...and cheap.
Re: Demon Body dimensions ? [Re: Chassisman] #641882
03/22/10 09:10 AM
03/22/10 09:10 AM
Arlington, Tx.
Arlington, Tx.
Anyone know the rocker to rocker measurements? This is one of the only things holding me up. That and having to put in a fence.
Re: Demon Body dimensions ? [Re: BJS racing] #641883
03/22/10 10:28 AM
03/22/10 10:28 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Not exactly sure what measurement you're looking for, but here is the measurement from the top pinch weld to the top pinch weld between the left & right rockers from a '72 Demon, it's 58" wide where the front seat bolts in.
Re: Demon Body dimensions ? [Re: GODSCOUNTRY340] #641884
03/22/10 03:35 PM
03/22/10 03:35 PM
Arlington, Tx.
Arlington, Tx.
I was looking for the dimension where the seams are on the bottom where the rocker seam is at the bottom of the car. But I think I can work with what you posted. Thank you very much!
