rear finish panel nuts #641461
03/15/10 11:40 PM
03/15/10 11:40 PM
Springfield VA
GTXOnsfri Offline OP
Springfield VA
Last question of the night. What do the nuts look like to attach the rear trim panel on a 68 GTX? The studs do not have any real threads. Do you use a washer and the nuts that cut into the stud? I don't know the name for them. If it doesn't snow again, I'd like to finish the panel. I have the argent paint, new reflective maroon strips and feel pretty confident that I can get the panel is good shape, just need to mount the darn thing. It just doesn't look GTX without it.
Re: rear finish panel nuts [Re: GTXOnsfri] #641462
03/15/10 11:48 PM
03/15/10 11:48 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
is there one on the other side to compare it to...
I call it a Acorn nut... does not use washer..
R/T Specialties carries them..
NUT ACORN 10-24
Re: rear finish panel nuts [Re: GTXOnsfri] #641463
03/16/10 08:57 AM
03/16/10 08:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm guessing but it looks like a #10 self threading pal nut
Re: rear finish panel nuts [Re: gtx6970] #641464
03/16/10 09:29 AM
03/16/10 09:29 AM
Springfield VA
Springfield VA
Thanks!!! I was all over RT Specialties but I didn't know what I was looking for. I'll order today and get my rear covered this weekend!
Re: rear finish panel nuts [Re: gtx6970] #641465
03/16/10 01:50 PM
03/16/10 01:50 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I don't think those are the acorn nuts he is refering to? The GTX may take a self threading open PAL nut with sealer? On my Barracuda, they are small 10-24 self locking open ended acorn type nuts but the studs on my finish panel are threaded. You may want to wait for someone with a GTX to send a picture of their original nuts?
Re: rear finish panel nuts [Re: RoadRunnerJD] #641466
03/16/10 01:56 PM
03/16/10 01:56 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
68 GTX's actually have a small foam washer on the panel itself that seal out the weather. The nuts themselves are a 2 peice design. One part is a cupped washer and the nut is an open back design. The reason it was designed this way is because the angles of the studs are not perfectly perpendicular to the trunk lid at all places. If I can find one I will post a picture of it.
Re: rear finish panel nuts [Re: RoadRunnerJD] #641467
03/16/10 01:57 PM
03/16/10 01:57 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Do a search on here for "68 GTX Trunk Panel" from back in January.I made the post.
You'll see pics near the end of the proper nuts and washers.
Re: rear finish panel nuts [Re: superwrench] #641468
03/16/10 03:05 PM
03/16/10 03:05 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Thanks superwrench, saved me from getting off my lazy butt today!
Re: rear finish panel nuts [Re: Paul Jacobs] #641469
06/08/12 02:18 PM
06/08/12 02:18 PM
Are you are looking for the cupped washer email me for a picture. I have not figure out how to add an image to the forums. Maybe my link will work?
[image]http://www.mrmoparts.net/search.php?search_query=270286&x=0&y=0[/image]
