Oil Pump Priming Rod
#641161
03/15/10 07:48 PM
03/15/10 07:48 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Whats the cheapest way to make one / buy one / find one / ect.??
Re: Oil Pump Priming Rod
[Re: StealthWedge67]
#641162
03/15/10 07:55 PM
03/15/10 07:55 PM
RapidRobert
Home Depot has a 5/16" hex paint stirring tool for cheap but I understand it may be too short. If you have an old intermediate shaft/gear grind the teeth back and use a rod w a flat screwdriver type bit on the end
[Re: Lefty]
#641168
03/15/10 09:00 PM
03/15/10 09:00 PM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Too expensive? The MP rod is only $7.95
http://www.summitracing.com/parts/DCC-4286800/
Well ... I will have that piece selling for 16 bux or so .. but as soon as I have them available ..I will run a 2 for 1 special .....
And I talked to MP a while back .. they are interested in my piece. P L U S ... the real-hard plastic coating PROTECTS the bushing from damage.
[Re: dOc …]
#641169
03/15/10 09:13 PM
03/15/10 09:13 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
I cut off a 5/16th allen wrench then used a 5/16th's socket and a 12" extension fitted in my drill. Worked like a champ.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: RapidRobert]
#641173
03/15/10 10:57 PM
03/15/10 10:57 PM
Challenger 1
Cincinnati, Ohio
Buy a 3/8" rod rod and grind a 5/16" hex on one end and your good to go.
Ding ding ding we have a winner (as double R would say ). I'd grind the OD smaller where it goes thru the bronze bushing and wrap some tape around it to make sure it doesn't hit the ID of the bushing.
No need for tape or grinding, it's already round, it can't hurt the bushing. Mine is the the one with yellow tape, the tape is only to identify it as a tool.
[Re: Lefty]
#641174
03/15/10 11:38 PM
03/15/10 11:38 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
The rod from Mancini is only $5.95...I understand about making one but it's not an expensive tool to buy. I don't know how you could mess up the bushing the tool is rigid and even with a drill hanging off the end of it it's still centered in the bushing.. I had mine running at 70lbs...
[Re: QuickBpBp]
#641176
03/16/10 12:08 AM
03/16/10 12:08 AM
Posts: 154 Escondido, CA
64physhy
Escondido, CA
Yeah, but if you want it now, it's a lot quicker to go to Home depot or somewhere to get something that it is to wait over a week for Mancini's.
[Re: 64physhy]
#641177
03/16/10 05:41 PM
03/16/10 05:41 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Summit has it for $2 more and shows to ship out same day...I agree in a pinch you could make something...I just knew I wanted one and picked it up at a show....
[Re: QuickBpBp]
#641178
03/20/10 06:54 PM
03/20/10 06:54 PM
dOc …
Florida STAYcation
BECAUSE ... if you are doing it alone ...and are barring the motor over ... the sharp hex part of the rod can cut-into the bushing.
SURE .. you can mod an old OEM drive-shaft .. but a hard plastic coated hex rod is far slicker.
