Brake Proportioning Valve Placement
#641084
03/15/10 06:34 PM
03/15/10 06:34 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
OK it talks about this thing in series with the rear brakes. Is this correct for a race only car with skinny fronts and wide slicks out back? I would think the valve would be better fit up front, seems like the front would need the adjustment to keep them from locking up first? This is the WilWood valve BTW. This is for the Dynalite Wilwood brakes also.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Brake Proportioning Valve Placement
[Re: sg66mopar]
#641087
03/15/10 07:05 PM
03/15/10 07:05 PM
my brake proportioning valve in right up front. with drums in the rear with no problems, you just have to set it to where you want it, thats why they call it an adjustable proportioning valve.mines to the left of the master cyl.
[Re: Bob_Coomer]
#641089
03/15/10 07:40 PM
03/15/10 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put it in the fronts... your trying to slow the fluid down so you dont lock the fronts... I have disc all the way around with it on the fronts
[Re: Bob_Coomer]
#641092
03/15/10 09:32 PM
03/15/10 09:32 PM
Thanks Guys.. I do have rear disc's also..
Bob, for the record, my 65 dodge and 63 plymouth both have front and rear discs and i dont have a proportioning valve.no problems whatsoever. i bought the 65 plymouth with the valve already there.
[Re: 68post]
#641094
03/16/10 08:33 AM
03/16/10 08:33 AM
MR_P_BODY
How much brake presure is needed to safely stop a car with disk brakes all the way around ? I have a Willwood master cyl with a 1 inch bore and am getting about 900 psi on the front and 1200 on the rear?
Thats a pretty good pressure for a normal stop, a panic type will be ABOUT 500-600 more(most likely locked up, depending on some other factors)
