How to ID K-Frame? #64105
05/26/08 06:05 PM
05/26/08 06:05 PM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
I'm attempting to verify that I have the correct K-frame in my '70 Challenger. I have checked the tech archive, but there is not a 7 digit number on the k-frame. It has 3 and 4 digit numbers in different spots and a coin with a (12) stamped on it. Nothing matches.
Any help would be appreciated.
Re: How to ID K-Frame? [Re: El-Rojo] #64106
05/26/08 07:14 PM
05/26/08 07:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
12 sounds like #2962012 - early 1970 V8 e-body (318, 340 & 383)
There is usually a 4 digit date code, what numbers are you finding?
Re: How to ID K-Frame? [Re: 6bblgt] #64107
05/26/08 07:30 PM
05/26/08 07:30 PM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
Front face- 3399 1
- Coin- 12
Top /Passenger- MK 42 1
Motor Mount/ Passenger- 40 1
The car is originally a 383, from the VIN.
Re: How to ID K-Frame? [Re: El-Rojo] #64108
05/26/08 09:53 PM
05/26/08 09:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
3399 is 339th day 1969 - Friday, December 5, 1969
should be close to your car's SPD
Re: How to ID K-Frame? [Re: 6bblgt] #64109
05/26/08 10:53 PM
05/26/08 10:53 PM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
Thanks. Just wanted to double check before I detail the frame.
