Re: Brake fluid DOT 3 vs DOT 5
[Re: ahy]
#640576
03/14/10 11:24 PM
03/14/10 11:24 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Thanks for the info and sorry for your engine compartment getting messed-up... It's amazing how much time it takes to strip,blast,repair,sand and paint just an engine compartment...Alot of cracked rough finger tips when done and I know I would be ![](/ubbthreads/images/graemlins/realmad.gif) if I ended up seeing it get messed-up.
[Re: ahy]
#640578
03/14/10 11:40 PM
03/14/10 11:40 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
the reason most people have trouble with DOT 5 brake fluid is because it retains AIR like DOT 3 does water. if you use DOT 5 leave a open bottle out in the sun for at least 1/2 hour to boil out the air that forms inside the bottles when it's shipped and handled. this is the reason it's sold in black bottles. or you can place a open bottle in HOT watter, about 200*, for about 20 min. when doing this you can watch the air bubble release from the fluid. some people tell me that it's boiling. that's not happening it's just the air releasing from the fluid. i use this method as much as possible.
when you install it in your car. suck out the old fluid in the master with a turkey baster or something like that, i use a old animal syringe that's rather large.
them pour in the new stuff and then bleed out the new fluid thru the lines. you can easily see the new stuff because it's purple.
use caution when bleeding the brakes. so SLOWLEY pump the petal so you don't form bubbles in the master.
also DO NOT ATTEMPT TO FLUSH the system with anything, the most often one i hear is alcohol. this will create problems when bleeding the brakes because it will compress more than brake fluid before getting hard and give you a spongy petal.
DOT 5 fluid will not gel when it's mixed with DOT 3. it won't mix with it eather. but they will not react to each other. when you mix them in a jar and shake they will look mixed but after time they will just separate.
hope this info helps. i have been using DOT 5, silicone, for over 10 years without any problems.
perception is 90% of reality
[Re: Mr T2U]
#640579
03/15/10 12:30 AM
03/15/10 12:30 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
That's funny because our DOT 5 is shipped in WHITE 1 gallon jugs.We use it everyday in the vehicles at work.No problems bleeding it,nor does it give a spongy pedal.
[Re: pishta]
#640581
03/15/10 12:40 AM
03/15/10 12:40 AM
Posts: 10,184 A Red State
SNK-EYZ
A Red State
Everyone I know that plays with old cars uses the DOT5 Silicone brake fluid and has for most of 20 years. Never had any problems with a spongy pedal or fade. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: last426]
#640584
03/15/10 08:36 AM
03/15/10 08:36 AM
Mr T2U
the only reason i said it's in black bottles is because that's the only way i have ever seen it. i only buy it 1 quart at a time. i am sure somewhere it's available in white quart and pint containers also.
the air bubbles problem is the reason why it's not recommended in use on anti lock braking systems.
if anyone has any doubts about my statements do a simple test. shake up some DOT 5 fluid. let it sit on the bench for several hours. now pour some, save some for later, into a container that's in boiling or very hot water. get the fluid up to around 200*. you will see air bubbles being released when it sits in the hot water. now let the extra fluid sit for a few weeks and do the water trick again. it will do the same thing as the freshly shaken fluid. i am sure some air will work it's way out by itself but there will be lots of air trapped into the system.
DOT 5's ability of retaining air is why you hear so many comments about how it will give you a spongy brake pedal.
one other thing to keep in mind it can allow water to stay in your brake system. over time the water in the fluid can mess your brake system up from the inside out. so every 4 or 5 years change the fluid. it also can get shaken up inside your master cylinder creating air bubbles. so if you brakes pedal starts to get soft. change the fluid and the hard pedal should return.
[Re: Bull1tt]
#640586
03/15/10 01:01 PM
03/15/10 01:01 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
DOT 5 is hydroscopic, it will absorb water! I agree with Mr T2U and change every few years, esp w/ steel lines.
no, DOT 5 silicone is not hyGROscopic. http://en.wikipedia.org/wiki/Hygroscopy
That's one of its major benefits!
The reason there still may be a water problem is that the water does NOT mix with the DOT 5, and it settles at the lowest point in the system, which is usually an expensive caliper. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DrCharles]
#640587
03/15/10 01:31 PM
03/15/10 01:31 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
dot 5 here,everything new,bleed by myself,just took longer,as i first did gravity,then slowly pumped pedal with master cap off,best pedal i've ever had,manual front disc rear drum ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: can.al]
#640589
03/15/10 11:42 PM
03/15/10 11:42 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
..this discussion will never stop. use Dot 3 with care and you will be fine take the lady out with the money you save
Already got Dot 5 and while I know I would be careful a leak is something I have no control over.. Thanks for all the info guys... Oh and it doesn't matter what I spend I still have to take my 2 boys and the "lady" out.. ![](/ubbthreads/images/graemlins/laugh2.gif)
