help me identify a 360 torque converter #640570
03/14/10 11:03 PM
03/14/10 11:03 PM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
I am looking for an easy way to identify a 360 torque converter and distinguish it from big block cast crank torque onverters. I am under the notion that 360 converters used either a singl 120 gram weight or two 60 gram weights. how do i tell that from loooking at it.
Re: help me identify a 360 torque converter [Re: Scott360] #640571
03/15/10 02:49 PM
03/15/10 02:49 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
All the ones I've seen have the big single house-type weight. The 440s I've seen are traditionally the 2-weight system.
Re: help me identify a 360 torque converter [Re: Scott360] #640572
03/15/10 05:58 PM
03/15/10 05:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The single 120 gram triangular weight measures 3.50" X 1.450". Each 60 gram weight measures 1.620" X .750".
Re: help me identify a 360 torque converter [Re: John_Kunkel] #640573
03/15/10 06:17 PM
03/15/10 06:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
One with the drains have a one smaller weight on each side of the drain plug. (= 2 weights) circled in blue. These weights shown are transplants off an OEM converter with a drain plug. These are off a 360.
