Gas Cap HELP???
#640416
03/14/10 09:25 PM
03/14/10 09:25 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
First off, I did not do this, but I have to live with it. The previous owner of my 69 Satellite wagon flush mounted this gas filler. Now the stock twist on type cap won't fit. Is there a locking or push on type cap I can use with this? Do I need vented or non vented for this year and model? Any and all help is appreciated. ![](http://img.photobucket.com/albums/v514/StukaJU87/002-5.jpg)
Scott
1969 Super Bee, 383/4 speed
Re: Gas Cap HELP???
[Re: Hemiruss]
#640418
03/15/10 07:10 PM
03/15/10 07:10 PM
StukaJU87
Northern NJ
The tank has an atmospheric vent coming off the fill tube, so I guess a non vented cap could be used. Do you think one of those locking caps used under the flip caps on a Charger would work? They are real expensive and I would hate to buy one and find it doesn't fit.
Scott
Post deleted by moparts
[Re: StukaJU87]
#640419
03/15/10 07:12 PM
03/15/10 07:12 PM
Re: Gas Cap HELP???
[Re: StukaJU87]
#640422
03/15/10 07:43 PM
03/15/10 07:43 PM
RapidRobert
Take the (3) screws and the whole assy off and go from there & see if you can pull the filler neck out to where it was or get another correct filler neck
