cam install centerline #640256
03/14/10 08:31 PM
03/14/10 08:31 PM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
have a mopar 557 cam putting into 383 b motor,906 heads 3800 turbo action convertor ,4.10 gears in a body ,what should i install cam centerline at ?spec is 110,
Re: cam install centerline [Re: top8x7b] #640257
03/14/10 09:43 PM
03/14/10 09:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would install it at 106 at least and as far advanced as 102 depending on your total package.
104
Re: cam install centerline [Re: top8x7b] #640258
03/14/10 11:38 PM
03/14/10 11:38 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
MP always suggests 2* advanced from its Lobe sep., in your case 108* Dont pay attention to that, with your 383 and 3800 stall id put it at 102* to 104* if IT valve clearence allows. mike
Re: cam install centerline [Re: top8x7b] #640259
03/15/10 07:22 AM
03/15/10 07:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
get a hold of Ron, he has his dialed in. I'd slam it in straight up. My 528 ran real good like that.
Coming soon!!!!
