Help! I can't remove upper control arm. #64003
05/26/08 04:23 PM
05/26/08 04:23 PM
Franksville, WI
g-man70 Offline OP
g-man70  Offline OP
Franksville, WI
I'm attempting to rebuild the front end on my '68 Charger but I hit a road block.. I can't get the drivers side upper control arm out. One of the bolts (torwards rear) appears to be fused to the bushing. I tried pounding the bolt out with a BFH, but is didn't budge... Anyone have any suggestions? Passenger side came out easily. Thanks
Re: Help! I can't remove upper control arm. [Re: g-man70] #64004
05/26/08 04:59 PM
05/26/08 04:59 PM
BDW Online content
BDW  Online Content
Soak it with some PB Blaster, let it sit awhile, then give the BFH another try.
Re: Help! I can't remove upper control arm. [Re: BDW] #64005
05/26/08 05:04 PM
05/26/08 05:04 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Yep and then heat if all else fails, thats why I like Florida cars!
Careful, your character's showing!
Re: Help! I can't remove upper control arm. [Re: g-man70] #64006
05/26/08 05:32 PM
05/26/08 05:32 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://cgi.ebay.com/ebaymotors/ws/eBayIS...E:IT&ih=016
By the time you get done, your going to need a set of upper control arm adjuster bolts that i sell.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Help! I can't remove upper control arm. [Re: hemi71x] #64007
05/26/08 06:22 PM
05/26/08 06:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And don't forget to unscrew the upper ball joint before you remove the UCA if that's in the plans also...
Re: Help! I can't remove upper control arm. [Re: screamindriver] #64008
05/26/08 07:59 PM
05/26/08 07:59 PM
Franksville, WI
g-man70 Offline OP
g-man70  Offline OP
Franksville, WI
I have the upper ball joints out already. I sprayed the areas with PB Blaster. If that doesn't work, I try using heat. I was concerned about the bushings, but I have new ones.
Re: Help! I can't remove upper control arm. [Re: g-man70] #64009
05/26/08 08:21 PM
05/26/08 08:21 PM
Asheboro NC
mopowertim Offline
super gas
mopowertim  Offline
super gas
Asheboro NC
PB blast n patience. You can also burn the old rubber out of the bushing with a torch- also try rapping the adjuster bolt with a drift and a 2 lb hammer to break the rust free.
If you can't outrun it-Outlaw it! The King
Re: Help! I can't remove upper control arm. [Re: mopowertim] #64010
05/27/08 03:42 PM
05/27/08 03:42 PM
Franksville, WI
g-man70 Offline OP
g-man70  Offline OP
Franksville, WI
OK, I tried PB Blaster..no luck, heat..no luck, drift..no luck(it just bent the cam). I'm starting to think that I'm going to have to cut the adjuster bolt out. Not sure how yet though. I have a grinder, saws all, and dremel. I think the grinder and saws all are too big, but I don't have a cutting disc big enough for the dremel.
Re: Help! I can't remove upper control arm. [Re: g-man70] #64011
05/27/08 03:53 PM
05/27/08 03:53 PM
tx
craigsmytcudas Offline
tx
hi i had two customer cars this year with the same problem.i used a sazall it took three blades each bolt aprox time 30 min .i cut at the rubber with the lip as a guide with the arm at full up position. it wont seem like progress untill you pass the hardend outer edge of your bolt then it gets easier good luck
Re: Help! I can't remove upper control arm. [Re: craigsmytcudas] #64012
05/27/08 03:57 PM
05/27/08 03:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said , you have to cut it in the wheelwell , get carbide sawzall blades if possible .
Re: Help! I can't remove upper control arm. [Re: JohnRR] #64013
05/27/08 04:37 PM
05/27/08 04:37 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
un new englanders are very fermiliar with that procedure...heck were surprised if we dont have to cut them!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Help! I can't remove upper control arm. [Re: pnypwr] #64014
05/27/08 06:36 PM
05/27/08 06:36 PM
Franksville, WI
g-man70 Offline OP
g-man70  Offline OP
Franksville, WI
Looks like the sawzall will work. I only had one blade and made it about 1/3 the way before it broke. I'll pick up more blades tonight and finish cutting tomorrow night. Thanks for the input!
Re: Help! I can't remove upper control arm. [Re: g-man70] #64015
05/27/08 07:27 PM
05/27/08 07:27 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Usually if you get enough toque to bust them loose they snap...
At least that is my experience... - HEAT does help...
