Re: Water only in cooling system, what corrosion inhibitor?
[Re: 69CHARGERMD]
#639990
03/14/10 06:12 PM
03/14/10 06:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run Water Wetter in mine
Same here... it has a lube in it also for the pump ![](/ubbthreads/images/graemlins/wave.gif)
Post deleted by Defbob
[Re: MR_P_BODY]
#639991
03/14/10 07:03 PM
03/14/10 07:03 PM
[Re: dartman366]
#639993
03/14/10 08:46 PM
03/14/10 08:46 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
X5,2 bottles with distilled water.
[Re: Chris2581]
#639994
03/14/10 09:01 PM
03/14/10 09:01 PM
Water Wetter is OK with alum heads?
[Re: galen]
#639997
03/15/10 12:16 AM
03/15/10 12:16 AM
Chris2581
Jacksonville, FL
If running aluminum heads,radiator etc.,put a sacrificial anode in the radiator if you can.The mail order box stores have them.I think Flex a Lite makes it.
