rear quarter resto question? #639919
03/14/10 04:54 PM
03/14/10 04:54 PM
Canada
Flatblack Offline OP
Canada
On my 72 charger, behind the rear tire, where the form bends in the middle of the body(horizontally) there are some tiny pitted rust holes along the line of that form bend. There are also some decent sized chunks that we cut out at the bottom of the rear quarter.
My dad wants to cut at the fold and replace the whole lower piece with some 20 gauge steel. My issue is, that I will loose the original form at the bend in that lower piece because it is not just a straight curve it has two different degree angles on it that keep the form of the body.......
Do they sell these little rear quarter pieces?Should I cut it.......?Is it a big deal? really we have been thinking on this for months now and need to move along......Input much appreciated!!
Thankx, just a student trying to save a buck! flatblack68@gmail.com
Re: rear quarter resto question? [Re: Flatblack] #639920
03/14/10 05:13 PM
03/14/10 05:13 PM
Central Illinois
mity225 Offline
mity225  Offline
Central Illinois
I'm thinking that a litte bondo covers a whole lot. If it's a matter of stressing on this or moving the project forward, just realize this is something that you'll spend little time with once you're behind the wheel.
It's almost summer. Let's drive 'em!
JK
Always looking for my next project!
Post deleted by moparts [Re: mity225] #639921
03/14/10 06:07 PM
03/14/10 06:07 PM
Re: rear quarter resto question? #639922
03/14/10 06:49 PM
03/14/10 06:49 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I'd cut out the rot and install patches. I'd cut out as little as possible. You can shape a small patch before you start welding. Just useing bondo will just by some time. Rot is rot and will keep growing if not cut out and replaced. But it doesn't sound like you need to cut much out.
Re: rear quarter resto question? [Re: Dougsmopars] #639923
03/14/10 08:23 PM
03/14/10 08:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm with the bondo idea. If its a major rust hole, use masking or duct tape behind the panel then slap the bondo on. If you can't get behind the panel to tape it that's fine, stuff it with newspaper then bondo it. Hell I've even fixed frames this way!
NOT !!!!
Re: rear quarter resto question? [Re: Stanton] #639924
03/14/10 09:46 PM
03/14/10 09:46 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
get an idea of how much of the area is rusted use a wire brush to knock the paint off. Cut and form the new piece of metal to the area by bending it so it sits on the area flat without rocking before you cut the rust out. Then cut the rust out test fit your piece tweek it if you need to. tack it in check it again if it's good stitch weld it in but keep the area cool so it won't warp on you I use a wet rag then clean it sand it fill it paint it and drive the bloody snot out of it. Sorry I don't have an after picture
Re: rear quarter resto question? [Re: Flatblack] #639925
03/14/10 10:07 PM
03/14/10 10:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you can post a pic that would help. If you weld in a new piece of metal and the curve is not exact, you can put a little bit of filler over top and shape it. Obviously the better shape your patch is, the better off you'll be and the less filler you will have to use.
Re: rear quarter resto question? [Re: Flatblack] #639926
03/14/10 10:44 PM
03/14/10 10:44 PM
Jacksonville Florida
elitecustombody Offline
I can get you AMD quarter patches ,it'll take out all the guess work and you'll have a perfect pieces to replace your rusted areas
Re: rear quarter resto question? [Re: DaytonaTurbo] #639927
03/15/10 03:20 PM
03/15/10 03:20 PM
Canada
Canada
heres the right rear quarter
Re: rear quarter resto question? [Re: Flatblack] #639928
03/15/10 03:21 PM
03/15/10 03:21 PM
Canada
Canada
2nd pic
Re: rear quarter resto question? [Re: Flatblack] #639929
03/15/10 03:27 PM
03/15/10 03:27 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Make sure you get the patch panel before you cut the car,you do not want to cut more off the car than the repair panel will cover. You have to make sure you cut enough of the panel off to get rid of all the rust,or you will be looking at rust bubbles around the areas you patched within a year. Sometimes the area around the rust spot may appear to be solid,but it may already be rusting from the inside out. You would be better off to cut beyond what you think you'll need to,than not enough. AMD makes good thicker than original patch panel with nice crisp lines. I would cut that above the body line,by how ever much is necessary to get to clean metal,and butt weld it together,if thats all the quarterpanel needs. If the car has spots of rust in front of the wheels,and over the wheelwell too,then you would be better off to put a full panel on the car,as your time and labor of doing the patch work thing will quickly outweigh the cost of the full panel,and there will be no seems to blend. The full panels are available for the 3rd generation Charger now. There's nothing worse than having rust return on a freshly painted car.
Re: rear quarter resto question? [Re: Flatblack] #639930
03/15/10 03:33 PM
03/15/10 03:33 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
2nd pic
I would replace with patch panel and do the trunk ext at the same time..Just my 2 cents
Re: rear quarter resto question? [Re: chargervert] #639931
03/15/10 04:27 PM
03/15/10 04:27 PM
Canada
Canada
I definately agree, this patch panel is my only rust problem aside from the rocker panels. The rest of the rear quarter is in mint condition, it's one of the reasons why I bought the car. I am going to have to look in to these patch panels then, I'll be sure to wait like you said and then cut the car when I have the actual panel patch in my hand.
Re: rear quarter resto question? [Re: Flatblack] #639932
03/15/10 07:42 PM
03/15/10 07:42 PM
Dougsmopars Offline
Dougsmopars  Offline
That's the right way to do it. I'd get the patches and cut off every thing the patch will cover and butt weld the whole patch on. Stuffing with plastic is not the answer. It will be bubbling back up in less then a year and you'll be doing the same job twice. Do it right once and it won't ruin a new paint job.
Re: rear quarter resto question? [Re: Dougsmopars] #639933
03/15/10 08:50 PM
03/15/10 08:50 PM
Canada
Canada
As far as I have learned bondo is only used when making a surface level true. This is only after you have attempted to do as much autobody/metal work to bring the metal to a true surface, covering rust is not a good idea, it's a temporary fix, although I was thinking if they didn't sell panel patches that I would try and fiber glass the tiny pitted holes to save the true body form.
Re: rear quarter resto question? [Re: Flatblack] #639934
03/15/10 09:19 PM
03/15/10 09:19 PM
Dougsmopars Offline
Dougsmopars  Offline
The only way to stop rust is to cut it out. Useing plastic or fiberglass will only cover it up for a short time. It will keep growing and bubble your new paint. Only lasting repair is to cut it out and weld in clean metal.
Re: rear quarter resto question? [Re: Dougsmopars] #639935
03/15/10 10:09 PM
03/15/10 10:09 PM
IN
ahy Offline
ahy  Offline
IN
I had a similar problem on the right rear of a Challenger. I'm no great bodyman or welder but I was able to carefully cut it out and fit a patch panel. I butt welded the panel on the top and used weld through primer on the lower laps. With some time in smoothing, body lines are fine. I'm confident it will hold up... and I do drive it in the rain.
Bondo repair lasts until the first time it gets wet or 3 months... whichever comes first. Fiberglass on rusted steel isn't much better... don't ask how I know.
Patch panels are readily available and not too expensive. Even if you are slow like me its less than a weekend project.
Re: rear quarter resto question? [Re: Dougsmopars] #639936
03/15/10 10:15 PM
03/15/10 10:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd cut it off as wel. I wasn't fortunate enough to have decent patch panels available. So I made my own. I used 10" pvc clamped to my bench. I slid a paint stick under each end of the pvc to hold it up off the bench. You can slide the metal under the pvc and roll it up around the pvc to get the curve you need. Trim to fit and butt weld it a little at a time. An hour spent welding slowly and letting it cool will save hours of headache later.here are the results.
Doug
Re: rear quarter resto question? [Re: dvw] #639937
03/15/10 10:16 PM
03/15/10 10:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The patches
Re: rear quarter resto question? [Re: dvw] #639938
03/15/10 10:17 PM
03/15/10 10:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The cut,I had already fabbed the quarter extension drops and welded them in.
