front end torque specs #639735
03/14/10 12:42 PM
03/14/10 12:42 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Anyone know the 1969 torque specs for the spindle bolts, joints, thanks
68 Satellite Wagon and a few other ones
Re: front end torque specs [Re: mro] #639736
03/14/10 05:43 PM
03/14/10 05:43 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
LCA pivot bolt = 140 ft.lbs. The two bolts holding the lower ball joint to the spindle = 120 ft. lbs. Upper ball joint to UCA = 125 ft.lbs. min. [ I go to 150 ft. lbs. ] Strut rod, rear = 105 ft.lbs. front = 55 ft lbs. Idler arm pivot bolt = 65 ft.lbs. Tie rod ends = 40-45 ft.lbs. Ball joints = good and tight, I've forgotten the actual specs.
Re: front end torque specs [Re: 5spdcuda] #639737
03/15/10 06:15 AM
03/15/10 06:15 AM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Thnaks!
