TTi big block header question #639350
03/13/10 11:42 PM
03/13/10 11:42 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
Does anyone know if the TTi 2 to 2 1/8 step headers for coil over and rack and pinion and raised exhaust port B1/INDY -1/SR heads will fit a low deck with ez heads? I am looking for a smoother flowing header for my 67 Coronet while the motor is out. It is a magnum force k member with a motor plate,rack and pinion and coil overs.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Post deleted by Defbob [Re: 67HEMI] #639351
03/14/10 02:23 AM
03/14/10 02:23 AM
Re: TTi big block header question #639352
03/14/10 05:20 AM
03/14/10 05:20 AM
IN
ahy Offline
ahy  Offline
IN
I have found the TTI website to be very helpful and also called TTI a couple of times on my combo (which is different from yours). They were very helpful. Its worth a call directly to TTI.
Re: TTi big block header question [Re: ahy] #639353
03/14/10 12:43 PM
03/14/10 12:43 PM
67HEMI Offline OP
67HEMI  Offline OP
I talked to Sam late Friday at TTi. He was going to mock up a low deck with some standard exhaust port heads and get back to me. I just thought some body on here may know of a set that works. I may end up with the Hookers back on it.
Re: TTi big block header question [Re: 67HEMI] #639354
03/14/10 01:36 PM
03/14/10 01:36 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I have a set on with -1's.
