Milling Edelbrock heads? #639237
03/13/10 09:40 PM
03/13/10 09:40 PM
Badham Co.
Y
Y3 70 BEE Offline OP
Y
Badham Co.
What is the most you can mill big block Edelbrock heads?
Re: Milling Edelbrock heads? [Re: Y3 70 BEE] #639238
03/13/10 09:49 PM
03/13/10 09:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
We cut .090 off of mine. Not sure how much farther it could have gone.
After the cut the chambers came down to 64.6 cc's.
Re: Milling Edelbrock heads? [Re: WILD BILL] #639239
03/13/10 09:53 PM
03/13/10 09:53 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
damn i didnt know you could go that far on them, i cut .050 on mine and havent decided if i want to max out the cam or cut the heads more
Re: Milling Edelbrock heads? [Re: n_bogie1984] #639240
03/13/10 10:17 PM
03/13/10 10:17 PM
Badham Co.
Y
Y
Badham Co.
I know this may not be the best set up but I was looking to put these on a 71 440 non hp stock piston motor with a 509 cam. Any ideas on how much the heads can be milled before I will get to close on piston to valve clearance? YA A JUNK MOTOR RECIPE.
Re: Milling Edelbrock heads? [Re: Y3 70 BEE] #639241
03/13/10 10:25 PM
03/13/10 10:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
How far in the hole are the pistons?
I ran a 555 solid lift cam W/ OOTB eddy heads and flat top pistons (no releifs) that were .102 in the hole with no contact.
Re: Milling Edelbrock heads? [Re: WILD BILL] #639242
03/13/10 11:23 PM
03/13/10 11:23 PM
Badham Co.
Y
Y
Badham Co.
Last time the heads were off the pistons were quite a bit down would have to check to know for sure. Thanks now I have a idea how much they could be milled just have to do some measuring.
Re: Milling Edelbrock heads? [Re: Y3 70 BEE] #639243
03/13/10 11:36 PM
03/13/10 11:36 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Always happy to help.
Take accurate measurments and let your machinist make the call
