Re: Need pics of BB 1 3/4 headers
[Re: Dart1031]
#639164
03/13/10 08:56 PM
03/13/10 08:56 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm not sure if all are routed this way or not.
I quoted this form David_in_St_Croi in another thread Quote:
We have Dynomax headers for a big block Mopar on the 452 in our 70 RR. They work better on the Edelbrock heads than they did on the old iron head son the 383 (same Edelbrocks were on the 383). Picture is of the 383. Going to a RobbMC starter helped a lot. A whack with a rubber deadblow hammer was needed on the starboard header to clear the Lakewood but as far as plugs go they are great and affordable. When they die I will likely use them as a model and make a set in 1-7/8 or 2"
They are 1-3/4" primaries.
Just tried to find the part number on Summit and they only show the painted version so maybe they stopped making them? If so bummer as they were an economical option. We have manual steering, it says the painted ones will not fit 67 coronet with power steering.
Good luck.
[Re: Dart1031]
#639168
03/14/10 09:30 AM
03/14/10 09:30 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Are you really gonna do it?... ...I hope so just so I can watch the faces on the "X" branders...
RIP Monte Smith
[Re: 383man]
#639170
03/14/10 07:56 PM
03/14/10 07:56 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Dont know if this will help any but these are the 1-3/4 hedmans on my 63. Ro
Don't mean to hi-jack,but what starter are you running with the hedmans?
[Re: pushbutton]
#639171
03/14/10 08:49 PM
03/14/10 08:49 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I actually use a Power Master mini starter. I just took the ext terminal off the stud and it fit fine. Ron
[Re: 383man]
#639172
03/14/10 09:27 PM
03/14/10 09:27 PM
pushbutton
tennessee
Thanks, I tried to use a MP lightweight with hedmans and it hit the # 1 tube. The full sise Mopar starter would fit,but not the small one. My headers are the 78030's. Thanks.
