Re: Small Block Timing Cover.
[Re: Fluffy]
#63874
05/27/08 12:38 AM
05/27/08 12:38 AM
Posts: 13,616 md
mopars4ever
md
[Re: mopars4ever]
#63875
05/27/08 12:40 AM
05/27/08 12:40 AM
Posts: 13,049 The Thumb O' Michigan
Fluffy
Automotive STD Guy
Automotive STD Guy
Fix your squealing belt?
Don't know, again. Coolant mixed with oil again. Let it drain and that's that until I fix it.
However, the alternator was about 2mm back, so I moved it up that.. hopefully that does it.
[Re: Fluffy]
#63876
05/27/08 01:17 AM
05/27/08 01:17 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
2mm? we dont speak metrics here, SAE please
[Re: GoodysGotaCuda]
#63877
05/27/08 02:25 AM
05/27/08 02:25 AM
Posts: 2,069 Renton, WA
GreenBlurr
super gas
super gas
Renton, WA
That doesnt soudn like something a traitor BMW tech would say
[Re: Fluffy]
#63881
05/28/08 08:23 PM
05/28/08 08:23 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
If the bolt was improper in anyway, could that cause it to leak through and be causing the oil/coolant mixture?
Just as long as the bolt is clamping tight no. You need to get those threads oil free by wire brushing them off and squirting them with Brake Parts Cleaner. Then put a light coating of Permatex RTV on those threads to keep the coolant in the block where it belongs. Let the RTV set up for 15 minutes before putting the bolt back in. I always coat the timing chain and water pump gaskets on both side with a very thin film of Permatex RTV after getting them oil free and very clean.
[Re: snuggles]
#63882
05/28/08 11:48 PM
05/28/08 11:48 PM
Fluffy
Automotive STD Guy
Automotive STD Guy
Did you get a new cover? Is the one your trying to use corroded?
Not yet, I work stupid hours and I'm slowly getting it apart. All I have to do is pull the bottom pulley off and damper tomorrow(hopefully)
I've just become severely paranoid now because it's one thing after another.
The bottom pulley is just the 6 bolts, and the crank bolt and the pulley and damper should come off no problem(knock on wood) Correct?
[Re: Fluffy]
#63883
05/29/08 03:46 AM
05/29/08 03:46 AM
you need a puller for the dampner.
[Re: Fluffy]
#63886
05/29/08 10:17 AM
05/29/08 10:17 AM
Posts: 15,540 Omaha Ne
TJP
Omaha Ne
I misplaced one of the water jacket bolts for the cover. I had replaced it with a bolt from work. Now, another dumb question (I'm good at racking these up)
If the bolt you repalced was the lower one on the drivers side and the replacement bolt was too long it will punch a hole in the #1 cylinder and cause a major coolant leak straight into the oil pan Hope that's not the case
Thanks.
[Re: TJP]
#63887
05/29/08 10:20 AM
05/29/08 10:20 AM
Fluffy
Automotive STD Guy
Automotive STD Guy
The first bolt I tried was longer. I didn't really tighten it, just put it in enough to see if it worked. Maybe that's what happened to be my luck.
