Re: overheating 440---could the head gaskets be on wrong???
[Re: F6F6Dodge]
#638705
03/13/10 11:45 AM
03/13/10 11:45 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
How far out are the cylinders bored?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: Dodgem]
#638709
03/13/10 12:35 PM
03/13/10 12:35 PM
Posts: 126 Indiana
F6F6Dodge
Indiana
New 5 core type radiator-------larger cam--pulls very little vaccuum around 11 pounds I think....standard 750 cfm Edelbrock carb...I'm thinking of taking the car to a Chassis Dyno to see if they can help---does this sound like a good idea or waste of money??? Cam size is the next larger than a six pack size...
[Re: F6F6Dodge]
#638711
03/13/10 01:00 PM
03/13/10 01:00 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Well if your rad hoses are not collapsing and water pump is good and circulating water well (is it) I would look to a lean condition. What kind of head gaskets?? The chassis dyno will give you an O2 reading?? What kind of water pump??
[Re: RapidRobert]
#638712
03/13/10 01:07 PM
03/13/10 01:07 PM
Dodgem
Ontario, Canada
come down as we have tried things to help, but the top of the motor get so hot that it wants to Vapor lock on me---(boils the fuel right out of the carbs)
(1) heat riser (2) retarded timing (3) lean). in that order
I was just on my way to the garage when a stuck heat riser came to mind!!!!
What heads and intake. have you used a temp gun to the intake, heads block!!
[Re: F6F6Dodge]
#638715
03/13/10 02:20 PM
03/13/10 02:20 PM
RapidRobert
Not a dumb Q at all, I learn here every day. the heat riser is the flapper valve on the outlet end of the pass ex manifold but w you having a blocked gasket that would take care of most of that potential heat source. When you start it how soon is it acting up? What do your plugs show? Water flows into the lower holes in the front of the block and flows around and to each cyl from front to rear and goes up into the heads via the holes above and below the cyls then circulates and exits the head(s) at the front of the heads into the large hole in the front block deck & a short turn to the 2 large top horizontle holes at the front of the block & into the pump housing. If you pull the heads I'd block the large hole at the rear of each block deck and drill a 1/2" hole in the deck and heads between cyls 2 & 3 between the head bolt holes (& punch a hole in the gasket) as this is the hottest area w 2 ex valves being paired side by side but I dont want to encourage you to do that at the moment as there is something else going on here
[Re: F6F6Dodge]
#638717
03/13/10 02:42 PM
03/13/10 02:42 PM
RapidRobert
OK no heat riser. Is the timing in the ballpark and what do the plugs look like? On adding an additional cooling passage on each deck/head it is needed between cyls 3&5 and 4&6 sorta between the outer head bolt holes (I'll have to post a pic). The 2&3 I posted was meant to mean between the 2nd and the 3rd cyl rearward from the front (on each bank) which is very misleading. Almost forgot, does it heat up around town or on the interstate or both. EDIT add a 1/2" hole between these 2 head bolt holes but upward in a triangle
