b body starter
#637267
03/12/10 12:06 AM
03/12/10 12:06 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i have a 1968 dodge coronet r/t 440/727 with headers and stock starter, the problem i am having, once the motor is run and the engine at normal temp, when i turn off the auto and try to crank back up, the starter sometimes clicks, i can try the key a couple of times ,then it spins over and cranks, then i can shut off car, and it cranks right up, it is kinda of like hit and miss, however the problem is always once the car has run for at least 5mins, i am thinking that the headers are heating up the starter and causing the problem, what can i put around the starter to protect from heat from the headers?
