Re: EFI Magnum and overdrive swap into a late-B...questions [Re: 71Dusterdan] #637042
03/14/10 01:25 PM
03/14/10 01:25 PM
Andrewh Online content
Andrewh  Online Content
yes you can. there are manual trans computers.
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: Andrewh] #637043
03/14/10 04:36 PM
03/14/10 04:36 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
That all sounds good. I actually have an A-999 in the car right now. I put it in last year so I could have a lockup converter and the lower 1st and 2nd gear ratios. The car has 3.21s in it right now. Would the overdrive trans be a good idea as well, or stick with the 999? I very rarely run the car on the expressway. 99% of my driving is city (40-50mph).
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: 69L78Nova] #637044
03/14/10 04:44 PM
03/14/10 04:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well if you're not concerned with cruising at over 50mph I think you just answered your own question.
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: DaytonaTurbo] #637045
03/14/10 05:32 PM
03/14/10 05:32 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
What I meant was if the addition of the overdrive trans would benefit that much in city driving?
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: 69L78Nova] #637046
03/14/10 06:34 PM
03/14/10 06:34 PM
Manitoba, Canada
Manitoba, Canada
It would benefit you little to nothing. I don't think the lockup converter or the overdrive gear kick in until near or over 50mph, and even at that speed without the overdrive you're not revving high enough to need that extra gear. Below that speed you're hauling around the extra weight for nothing.
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: DaytonaTurbo] #637047
03/14/10 08:33 PM
03/14/10 08:33 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Thats kinda what I figured. I was contemplating eventually doing a swap to 3.55s down the road if I do the OD swap as well. With a 27" tire and 3.21 gears, I figured it might lug a bit around town
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: 69L78Nova] #637048
03/14/10 08:53 PM
03/14/10 08:53 PM
Manitoba, Canada
Manitoba, Canada
3.21 to 3.55 is only going to be around a 200rpm difference at 50mph. You could swap all the way up to 4.10 gears and still only be doing 2600 at 50mph. Play with this calculator and see for yourself:
http://vexer.com/automotive-tools/speed-rpm-calculator
Re: EFI Magnum and overdrive swap into a late-B...questions [Re: DaytonaTurbo] #637049
03/14/10 10:18 PM
03/14/10 10:18 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I have a 3;55 behind my 999 with 28 in tires, and it is a great ratio for the city and fun.......
engine is a 5.9
Dan
