REAR AXLE VENT #63680
05/26/08 09:57 AM
05/26/08 09:57 AM
Northwood, Ohio
JJ300 Offline OP
JJ300  Offline OP
Northwood, Ohio
I seem to be losing gear fluid in the area where the brake lines go into the ftting on top of the axle. Looks like there is some sort of vent cap here that goes thru this fitting? I am sure it gear fluid, not brake fluid. what causes this, how do I fix?
Re: REAR AXLE VENT [Re: JJ300] #63681
05/26/08 09:58 AM
05/26/08 09:58 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The rear may be over filled with gear oil.
Re: REAR AXLE VENT [Re: 69Cuda340S] #63682
05/26/08 10:04 AM
05/26/08 10:04 AM
Northwood, Ohio
JJ300 Offline OP
JJ300  Offline OP
Northwood, Ohio
I don't think that is it, I filled it to the bottom of the side hole. Never had this happen before on other cars. Do you know is this a vent, or is it a screw just to hold the fitting in place?
Re: REAR AXLE VENT [Re: JJ300] #63683
05/26/08 10:11 AM
05/26/08 10:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its a vent.Lets pressure release from the raer.Where is the oil coming from?The vent bolts do get plugged at times.Rocky
Chrysler Firepower
Re: REAR AXLE VENT [Re: therocks] #63684
05/26/08 10:23 AM
05/26/08 10:23 AM
Northwood, Ohio
JJ300 Offline OP
JJ300  Offline OP
Northwood, Ohio
It's wet in that area, around the fitting. So I thought if it was just a scrwew holding the fitting in, i could take it out & put some sealant around the threads. But if it's a vent, it had me worried that there was pressure getting built up in there, and forcing the fluid out. Will it hurt anything to plug it if it were a vent?
Re: REAR AXLE VENT [Re: JJ300] #63685
05/26/08 10:29 AM
05/26/08 10:29 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Don't plug it or you'll have the axle seals leaking. Take the vent out, make sure it is open and reinstall it. You can put sealant on the threads if you like just make sure the vent is working.
Re: REAR AXLE VENT [Re: GODSCOUNTRY340] #63686
05/26/08 10:32 AM
05/26/08 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
as said its a vent and oil shouldn't be leaking out of it unless its way overfilled . if its not gear oil its brake fluid
Re: REAR AXLE VENT [Re: GODSCOUNTRY340] #63687
05/26/08 10:33 AM
05/26/08 10:33 AM
Northwood, Ohio
JJ300 Offline OP
JJ300  Offline OP
Northwood, Ohio
Ok, the cap on it has a spring loaded rubber seal. The seal is wet, so it seams as though the vent is open, not plugged. I'll take out the fitting, seal the threads, maybe find a little heavier spring to put behind the rubber seal. Hopefully that will do it.
Thanks everbody....any other input is greatly appreciatd!!
