Re: 70 cuda console
[Re: Yesdogjr]
#636808
03/11/10 04:29 PM
03/11/10 04:29 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
as far as I know, they're the same, but I've not seen a 4spd side by side with an auto, so I don't know for sure.
if I do swap mine over to a manual, I was planning on just making a new top plate, probably from REAL WOOD, instead of that metal plate with ugly fake sticker on it. might not be correct, but who cares?
**Photobucket sucks**
Re: 70 cuda console
[Re: 318 Stroker]
#636810
03/11/10 04:46 PM
03/11/10 04:46 PM
DaytonaTurbo
Manitoba, Canada
The bottom half of the console is different between auto and 4-speed. They have have their own distinct cut-out to conform to the tunnel "hump" in the car. You can cut an auto console to the 4-speed profile, but not the other way around. Someone on here should be able to provide you with a template to turn your auto bottom piece into a 4-speed bottom...
There is a template floating around for cutting the auto console for 4-sp. However, personally I prefer the look of a 4-sp without console so all you see is flat carpet with that pistol grip sticking up.
