new one piece oil pan gasket for the 360LA #636673
03/11/10 12:51 PM
03/11/10 12:51 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Its hard to find, but there is a one piece oil pan gasket available for the 360LA. its a Milodon piece. jegs has them on back order, but i bought mine direct from Milodon for $30 plus the ride. can be bought under part #41007.
Re: new one piece oil pan gasket for the 360LA [Re: mopar dave] #636674
03/11/10 01:03 PM
03/11/10 01:03 PM
Hartford, MI
MoparSprinter360 Offline
Hartford, MI
Looks a lot like a Fel Pro OS34409R.
Re: new one piece oil pan gasket for the 360LA [Re: MoparSprinter360] #636675
03/11/10 01:39 PM
03/11/10 01:39 PM
Mt Morris Michigan
Mt Morris Michigan
there is a fel-pro one piece available to fit the 360 magnum, but not the LA.
Re: new one piece oil pan gasket for the 360LA [Re: mopar dave] #636676
03/11/10 02:39 PM
03/11/10 02:39 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I just put a Mopar stock replacement one on my 360 Crate short block. I just asked for a pan gasket for a 96 360 at my local dealer. I like the one piece pan gasket better than the one I had with the rail and end gaskets seperate. I always seemed to have a leak so I`m hoping this new gasket with Right Stuff does the trick. So far so good.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: new one piece oil pan gasket for the 360LA [Re: mopar dave] #636677
03/11/10 07:35 PM
03/11/10 07:35 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Is there a one piece avaliable for a 318/340 LA
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: new one piece oil pan gasket for the 360LA [Re: MoparSprinter360] #636678
03/11/10 11:06 PM
03/11/10 11:06 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Ditto, a 360 magnum 1 piece gasket works just fine on an LA 360 block... Just put one on my 408 stroker (LA block)
The way you can tell a 5.9 magnum gasket (dave's) is that the rail gasket dips in between the 3-4 bolt holes.
As far as for a 318/340, i'd check on a 5.2 magnum pan gasket. It might work, but i'm not sure. If you're at the partstore, check the part # of a 5.2 vs. 5.9 pan gasket...
Re: new one piece oil pan gasket for the 360LA [Re: 340_Dart] #636679
03/12/10 12:20 AM
03/12/10 12:20 AM
AndyF Offline
AndyF  Offline
A 5.2 Magnum pan gasket is basically the same as a 5.9 Magnum pan gasket. They are a different part number but it is really hard to see the difference. Basically just two little nubs where the rear seal meets the rails. Not even sure why they bothered creating a second part number.
Re: new one piece oil pan gasket for the 360LA [Re: AndyF] #636680
03/12/10 10:03 AM
03/12/10 10:03 AM
Mt Morris Michigan
Mt Morris Michigan
milodon told me they had one for a 340, but its not listed on their site. i thought the fel-pro one piece magnum seal did'nt have the front pan seal on it and had to be sealed with sealant?
Re: new one piece oil pan gasket for the 360LA [Re: mopar dave] #636681
03/12/10 11:02 AM
03/12/10 11:02 AM
NY usa
540challenger Offline
NY usa
Correct the magnum gasket can be made to work however you have to seal it.
There are pictures in this link.
https://board.moparts.org/ubbthreads/show...ID=&fpart=1
