Page 3 of 3 1 2 3
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636195
03/14/10 12:23 AM
03/14/10 12:23 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
11
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636196
03/14/10 12:24 AM
03/14/10 12:24 AM
N
N
12
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636197
03/14/10 12:24 AM
03/14/10 12:24 AM
N
N
13
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636198
03/14/10 12:26 AM
03/14/10 12:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I do not have my car assembled. But I did do a mock up. I have a hemi with 2 1/8 tti headers.
Pete did you mock up the headers on the engine with the bellhousing in place as well,..SOME TTI's header tubes on the passenger side will contact the lower lip of the Keisler bellhousing where the inspection cover bolts too,...may need a trim on the corner flange of the bells inspection cover lip, otherwise it puts stress on the header flange as you bolt it to the engine, or if the engine is in with the headers bolted, you won't be able to mount the bellhousing due to interference
Mike
Re: Anyone running a keisler 5 speed with TTi headers? [Re: DAYCLONA] #636199
03/14/10 12:35 AM
03/14/10 12:35 AM
N
N
Mike if you mean where number 2 tube runs? Yes I did make some minor mods. Cant remember what I did as it was so mind frightning. Not for the weak of heart [lol].
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636200
03/14/10 12:36 AM
03/14/10 12:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looks good Pete,....sitting up high in the tunnel like it should,...I notice your not running a 4 spd factory hump?....you'd gain a little more room around the tranny with it,....would really help with heat, as the Keisler when driven in OD mode for extended time periods puts off enough heat to fry Bacon and eggs on it ....you should put down some dynamat, the non adhesive foil kind, any adhesive, esp the tar type will only heat up and stink out your car
Pete,...did you ever get the 3rd gen shift tower from Richard at Keisler to upgrade?...as I see the Gen 1 in your pics
Mike
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636201
03/14/10 12:47 AM
03/14/10 12:47 AM
N
N
Better pic.
Re: Anyone running a keisler 5 speed with TTi headers? [Re: DAYCLONA] #636202
03/14/10 12:57 AM
03/14/10 12:57 AM
N
N
Mike I did get the upgraded tower. A while back when I posted some pics you mentioned that there could be some minor issues, I was contacted by the guys at keisler and sent upgraded parts at no charge. It is obvious that they watch and respond to the buyers of their products.
While I have to admit my project is not mobile I have had support. There again I went by direction and cut the hole in the floor as told. I did it my way and all told the included templete was just about spot on.
We may have to talk one day.
Re: Anyone running a keisler 5 speed with TTi headers? [Re: NITROUSN] #636203
03/14/10 01:18 AM
03/14/10 01:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That little "devil" grin scares me ....good to hear you got the Gen 3 tower, as it greatly improves the overall shifting performance of the Keisler, and eliminates or greatly lessens the "buzzsaw" effect of the shifter in certain RPM ranges when in OD mode
Mike
PM anytime
Re: Anyone running a keisler 5 speed with TTi headers? [Re: DAYCLONA] #636204
03/14/10 04:57 PM
03/14/10 04:57 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Well, seats are out, carpet is out and tunnel ready to be "modified". The cutting will begin tomorrow!
Re: Anyone running a keisler 5 speed with TTi headers? [Re: 69charger440_6pa] #636205
03/14/10 06:10 PM
03/14/10 06:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Do yourself a favor Ryan and purchase a magnetic inclination meter to measure the transmission centerline in relation to the drive shaft, and rear pinion angle, so that you can "dial in" your set up as recommended in your Keisler install instructions
These are listed in McMaster Carr, they range from $8-$45
Mike
Re: Anyone running a keisler 5 speed with TTi headers? [Re: DAYCLONA] #636206
03/14/10 06:41 PM
03/14/10 06:41 PM
Oakley CA
Oakley CA
I have one, thanks for the heads up
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Anyone running a keisler 5 speed with TTi headers? [Re: 69charger440_6pa] #636207
03/14/10 10:41 PM
03/14/10 10:41 PM
Oakley CA
Oakley CA
Well I went ahead and made the cut today since I had a little spare time and I am a little disappointed. After cutting the tunnel I was only able to raise the tranny 1/2" before it bottomed out on the torsion bar crossmember. Guess my headers are always going to hang low.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Page 3 of 3 1 2 3
