Re: superbee wiring problem
[Re: nates69b]
#63604
05/26/08 02:48 AM
05/26/08 02:48 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
make sure the fuses are good. make sure power is getting to fuse block. make sure you have a good ground to the body of the car, you may have to scratch that new paint
[Re: 451Mopar]
#63607
05/26/08 11:11 AM
05/26/08 11:11 AM
451 mopar, could it be because I dont have a engine ground strap?
yes.
NO
An engine strap won't cause this problem. Frankly, it sounds like you have multiple problems. Do you have power on both sides of the fuses? Have you done any test lamp probing at the connector in the kick panel, on the way to the rear harness?
I can't think of any one problem that will cause all this
For example, your wipers should not be connected to the lighting problem.
If it was the infamous ammeter/firewall connector problem, then none of the lights should work
