Mounting of After Market Coils
#635635
03/10/10 12:11 PM
03/10/10 12:11 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am looking for some pictures of where/how you mounted your after market ignition coils. I made a bracket for mine that uses the top two brake master cylinder mounting studs. This will locate the coil above the master cylinder up and away from the engine heat. I would like to see other coil locations before I start wiring in case I want to move mine again. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Mounting of After Market Coils
[Re: Lefty]
#635638
03/10/10 12:42 PM
03/10/10 12:42 PM
YO7_A66
Indiana
Thank you for the replies.
Lefty: What coil brand/# is that? Thanks
[Re: Lefty]
#635639
03/10/10 12:45 PM
03/10/10 12:45 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
On the fender near the distributor.
Ride eternal, shiny and chrome
[Re: Lefty]
#635640
03/10/10 12:50 PM
03/10/10 12:50 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I made a bracket to work with the original coil bracket bolt holes on the intake manifold.
I really like that, mine is on the inner fender right now... Any pics of just the bracket?
[Re: challenger70]
#635642
03/10/10 04:04 PM
03/10/10 04:04 PM
Posts: 6,516 Santa Cruz, California
Lefty
As I recall it's very basic, just a flat piece of aluminum with 2 holes drilled for the old mounts and then 4 new holes for the new coil. Check to make sure the air cleaner has clearance before marking and drilling the new coil holes. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: AndyF]
#635645
03/10/10 05:36 PM
03/10/10 05:36 PM
DaytonaTurbo
Manitoba, Canada
Here is another bracket that I made for a different MSD coil. This idea is like the one that Lefty showed.
That's the same coil I run, but I thought the instructions said to keep it away from direct engine heat and vibration..?
[Re: YO7_A66]
#635646
03/10/10 05:57 PM
03/10/10 05:57 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Aftermarket coil, but shaped the same as OEM. ![](/ubbthreads/images/graemlins/scope.gif) .
Down to just a blue car now.
[Re: YO7_A66]
#635647
03/10/10 07:41 PM
03/10/10 07:41 PM
RapidRobert
Off topic, what was the concensus on a prior thread: that stock coils should be mounted horizontle (like oe) and epoxy filled ones could go either way?
[Re: RapidRobert]
#635648
03/10/10 08:31 PM
03/10/10 08:31 PM
YO7_A66
Indiana
I was told by Mallory that the epoxy coils can be mounted in ANY orientation. This is how I ended up mounting mine, away from the engine heat and a 22" Firecore coil wire ![](/ubbthreads/images/graemlins/thumbs.gif) . Thanks again for the replies.
[Re: YO7_A66]
#635649
03/11/10 08:25 AM
03/11/10 08:25 AM
YO7_A66
Indiana
Here is another view.
Note: The 22" Firecore coil wire measured 5X less resistance than the Taylor 14" coil wire that I removed. I will be getting a full set from Rick as soon as the budget allows.
