stage vI heads Intake questions
#634989
03/09/10 06:50 PM
03/09/10 06:50 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a 499 rb stroker and I have stage vI heads on it with a m1 stage vI intake. my heads are not the big max wedge ports so from what I am reading is they have stock port location. I thought I had to run the m1 intake but will any rb intake work on it? I have a 4150 intake with a 2" 4500 adaptor and not much hood clearance. can I run any rb intake? I was thinking mine were the raised port but they do not have the offset rockers. They are ported and cut way down to get them to 72cc chambers. Are these heads going to make decent power with my 12.5 to 1 499? The heads have been completely reworked so its not the quality issue on them just will they make power like i was thinking?
67' charger 499 RB
10.57 at 127
Re: stage vI heads Intake questions
[Re: buildanother]
#634991
03/11/10 03:10 PM
03/11/10 03:10 PM
dragram440
bigfork mn
will these heads make decent power on my 12.5-1 499. rb?
67' charger 499 RB
10.57 at 127
[Re: buildanother]
#634993
03/12/10 12:09 AM
03/12/10 12:09 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
there were 2 stage VI manifolds produced.. the normal ![](/ubbthreads/images/graemlins/scope.gif) port and the max wedge port
I am truckless..
[Re: 340SHORTY]
#634994
03/12/10 10:17 AM
03/12/10 10:17 AM
dragram440
bigfork mn
I do not have the max wedge ports. Are you talking about the oil drain off the spring pockets? I dont have the flow numbers anymore but I did some checking when I bought them and they were pretty decent numbers.
67' charger 499 RB
10.57 at 127
