Best adhesive remover needed.. #634892
03/09/10 04:00 PM
03/09/10 04:00 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
I need to remove a 40 plus sticker.. I have tried Goo Gone..It's junk as far as I am concerned...
Pic of sticker
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634893
03/09/10 04:02 PM
03/09/10 04:02 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
heat gun-
Re: Best adhesive remover needed.. [Re: Kirby] #634894
03/09/10 04:05 PM
03/09/10 04:05 PM
3
Parts Problem
Parts Problem
3
heat gun-
tried it...slow going..
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634895
03/09/10 04:11 PM
03/09/10 04:11 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Gasoline. Soak a rag in it and let it sit on the sticker for a couple minutes. Should penetrate through the sticker to the glue and loosen it up.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Best adhesive remover needed.. [Re: bigsbigelow] #634896
03/09/10 04:19 PM
03/09/10 04:19 PM
north wisconsin
shadow456 Offline
shadow456  Offline
north wisconsin
hi, i just took off 383 hood decals on 71 RR, i used klean strip aircraft brand decal remover no. EAD-908 from body shop supply, about 15.00 a spray can. it works after a few times sitting on it, these are some tough decals! it didn't hurt original 71 paint underneath.
Re: Best adhesive remover needed.. [Re: shadow456] #634897
03/09/10 04:24 PM
03/09/10 04:24 PM
3
Parts Problem
Parts Problem
3
my main concern is not to soften or deface the part..
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634898
03/09/10 04:42 PM
03/09/10 04:42 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Maybe try some mineral spirits and test an inconspicuous area first.
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634899
03/09/10 08:53 PM
03/09/10 08:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
WD-40
Re: Best adhesive remover needed.. [Re: John_Kunkel] #634900
03/09/10 08:56 PM
03/09/10 08:56 PM
3
Parts Problem
Parts Problem
3
WD-40
really..??
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634901
03/09/10 09:27 PM
03/09/10 09:27 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
WD40 is known for that. When I didn't have any, I have used mineral spirits to remove OLD stuck on duct tape from my vinyl back seat. I used a drill with one of those brillo wheels on it, and covered the brillo wheel with a hand towel with some mineral spirits on it. Otherwise it would have been a lot of manual labor..
Re: Best adhesive remover needed.. [Re: Exit1965] #634902
03/09/10 10:09 PM
03/09/10 10:09 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I like 3M adhesive remover but I've never tried it on something that old.
Ride eternal, shiny and chrome
Re: Best adhesive remover needed.. [Re: DirectSubjection] #634903
03/09/10 10:44 PM
03/09/10 10:44 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
The 3m stuff is the best I've ever used. What is that piece made of?
Re: Best adhesive remover needed.. [Re: GTXKen] #634904
03/09/10 11:04 PM
03/09/10 11:04 PM
3
Parts Problem
Parts Problem
3
kinda like fiberglass...color is impregnated..has fiber in it
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634905
03/09/10 11:17 PM
03/09/10 11:17 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
Might want to stick with the heat gun...slow but safe
Re: Best adhesive remover needed.. [Re: GTXKen] #634906
03/09/10 11:54 PM
03/09/10 11:54 PM
3
Parts Problem
Parts Problem
3
To be honest.. It was a Hair Dryer..guess I might need to buy a heat gun ..
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634907
03/10/10 04:06 AM
03/10/10 04:06 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Hopps #9 nitro solvent (gun cleaner.)
I have used it to remove stickers from soft plastic parts, and it seems to remove the stickers adheasive without harming the plastic. I have never used it on fiberglass, so you may want to test it in an unseen area first?
Re: Best adhesive remover needed.. [Re: 340dart4spd ] #634908
03/10/10 10:57 AM
03/10/10 10:57 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Harbor Frieght has cheap ones. I use their junk all the time for one shot applications. If you were going to do a lot of them, I would invest in quality.
Craig
Re: Best adhesive remover needed.. [Re: denfireguy] #634909
03/10/10 11:01 AM
03/10/10 11:01 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
be careful with a real heat gun though, don't get the part too hot...since it's not fiberglass, but something similar, who knows how it'll hold up to heat. you try a razor blade and scrap it off? be really careful to not scratch the part though, since it's not glass or metal
**Photobucket sucks**
Re: Best adhesive remover needed.. [Re: 70Cuda383] #634910
03/10/10 12:57 PM
03/10/10 12:57 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Lacqure Thinner works well too. That is why it is called the "MAGIC JUICE"....
