8 3/4 sure grip Q #634329
03/08/10 07:54 PM
03/08/10 07:54 PM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
Can a clutch style sure grip from a 741 housing be swapped into a 742 housing with the housing appropriate gears?
Re: 8 3/4 sure grip Q [Re: Runnin74] #634330
03/08/10 07:55 PM
03/08/10 07:55 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
yes
Re: 8 3/4 sure grip Q [Re: Mopar-Al] #634331
03/08/10 11:19 PM
03/08/10 11:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use the side bearings for the sure grip unit.
Re: 8 3/4 sure grip Q [Re: MoparforLife] #634332
03/09/10 12:48 AM
03/09/10 12:48 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
AND if reusing gears, measure the backlash BEFORE you take the set you are using apart, then put it back THE SAME when you put it back together with the sure grip in it.
This should keep it quiet
Re: 8 3/4 sure grip Q [Re: dave571] #634333
03/09/10 12:54 AM
03/09/10 12:54 AM
& I think you want to keep the races w the bearings also
Re: 8 3/4 sure grip Q [Re: RapidRobert] #634334
03/09/10 08:04 AM
03/09/10 08:04 AM
Upper Midwest
Upper Midwest
Was talking complete bearing assembly.
Re: 8 3/4 sure grip Q [Re: MoparforLife] #634335
03/09/10 09:51 AM
03/09/10 09:51 AM
Yeah after several seconds of thought that does makes sense that you were referring to the whole assy's
