2006 Weak A/C vents #634160
03/08/10 05:22 PM
03/08/10 05:22 PM
NC
DCM71cuda Offline OP
NC
Noticed today that the air coming out of the dash vents on my truck is weak, even if the blower is turned on high. If I switch to the floor vents, it seems to be normal in terms of the blower strength.
Poking around online, I've seen references to problems with the fresh air door...does this sound like the problem I've got??
If so, what is the $$$ to fix.
Thanks.
Re: 2006 Weak A/C vents [Re: DCM71cuda] #634161
03/08/10 07:30 PM
03/08/10 07:30 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
