Help decipher converter numbers #634149
03/08/10 05:19 PM
03/08/10 05:19 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Anybody have any idea if these numbers can tell me anything about this converter? It measures 10 inches across, is about all I know.
11731 3353390
Thanks,
John
Re: Help decipher converter numbers [Re: PS Arrow] #634150
03/09/10 12:56 AM
03/09/10 12:56 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
If you know who made it..They can look up the specs based on your number.
Re: Help decipher converter numbers [Re: PS Arrow] #634151
03/09/10 08:39 AM
03/09/10 08:39 AM
NC USA
U
ultimatelenny Offline
U
NC USA
Hi That would be a Dynamic 10" street converter built back in 1990. Behind a mild small block you should see approx.3200-3500 stall, behind a mild big block you should see approx 3600-4000 stall, of course this will very depending on your particular combo and variables. Hope this helps you out a little.
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: Help decipher converter numbers [Re: ultimatelenny] #634152
03/09/10 09:51 AM
03/09/10 09:51 AM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
That helped a bunch!!! Thank You Lenny!!!
