sb stroker carb recommendations??? #633382
03/07/10 10:11 PM
03/07/10 10:11 PM
las vegas
70challenger408 Offline OP
las vegas
Just got done with the sb 408 upgrades. I changed heads/cam/torque converter. the heads are ootb indybrocks, 1.5/1.6 rockers. cam is Comp solid roller 248/254 @ .50", 616/582 lift. tq is a reworked dynamic 9.5 with 4100 stall. Just got it all up and running, but seems like carb problems(currently has a 750 mighty demon). runs real rich, and has idle problems. is the carb too small???? what are you guys using for sb 408 strokers??? trying to get this ready for mopars at the strip.
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633383
03/07/10 10:18 PM
03/07/10 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run a 1050 dominator on mine, list 9375 and it work's real well, if you want to stay with a 4150 style then get a 950 or a custom 1050, those 408's like a lot of manifold plenum and a big carb.
Re: sb stroker carb recommendations??? [Re: dartman366] #633384
03/07/10 10:21 PM
03/07/10 10:21 PM
las vegas
las vegas
I have a victor 340 intake on the engine right now. I also found a mighty demon 850 in the garage, think i should swap to that?
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633385
03/07/10 10:32 PM
03/07/10 10:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Yes,, as long as it is a known good carb.
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633386
03/07/10 10:41 PM
03/07/10 10:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know of a few that have had problems with Demons
specially on idle... I believe a 750 is too small
for your 408.... I run a 1050 on my 405ci... but
RPM has something to do with the carb selection
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633387
03/07/10 11:14 PM
03/07/10 11:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not to hijack, but what if a Indybrock 408 similiar cam but for road race with E-85 and 6000rpm max? Throttle response being more important then max output. 750, 850 or 950?
Re: sb stroker carb recommendations??? [Re: jcc] #633388
03/07/10 11:17 PM
03/07/10 11:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For throttle response go with a smaller carb like a 750
specially with 6000 max
Re: sb stroker carb recommendations??? [Re: MR_P_BODY] #633389
03/07/10 11:25 PM
03/07/10 11:25 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i have a 950 pro systems on mine it flows 830 cfm wet ,that's about the same as your 750 ,bg 850 flows a 1000 cfm i can get 1050 domanator thinking of trying this to see if there is any difference next sunday i can post results then
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: sb stroker carb recommendations??? [Re: Ian] #633390
03/08/10 02:36 AM
03/08/10 02:36 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
My 408 is all done at 6200rpm, and it is actually more throttle responsive with the 1000cfm quickfuel carb than it was with the proform 750! Must have been the tune, but I also picked up 2 tenths with the switch to the bigger carb. (M1 single plan with a one inch Wilson spacer) Also, the increase was observed on pump gas originally, and now still works great with the E85.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633391
03/08/10 09:15 AM
03/08/10 09:15 AM
Az
Crizila Offline
Crizila  Offline
Az
Running a very similar set up to yours ( 750 mighty demon annular discharge and idle-eze ). Same rich issues @ idle - could'nt go more than 1/2 turn out with mixture screws before it was way rich. I was told by Grant to change the idle feed restrictors from .036 to .033". Didn't seem to help. I went ahead and opened up the idle-eze air bleed holes about .003 ( all 4 holes ). This seemed to help. I was able to get enough air in to where I could close up the throttle blades a bit and assure I was staying out of the transition slots. I've been thinking about going to a little bigger carb also, but I run a very heavy car and 3500 stall convertor / 4.10 gear and concerned with hurting 60 foots?
Fastest 300
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633392
03/08/10 09:57 AM
03/08/10 09:57 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I'm currently running a 750hp carb on mine with pv's blocked and it's very crisp and idles well.590mp cam and Super Victor intake but i'm still looking at purchasing a 950hp stage 7 from BIGS as i feel there's more in that combo with a bigger carb.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: sb stroker carb recommendations??? [Re: 77DragracerR/T] #633393
03/08/10 12:33 PM
03/08/10 12:33 PM
las vegas
las vegas
would you guys run a demon, or a QFT. 1050 on the street???
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633394
03/08/10 12:53 PM
03/08/10 12:53 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Try the bg 850, its a large venturi big plate 850, they can flow 1000 cfm with the small down leg booster, you need to play with all the BG carbs for running rich, they don't adjust the same as as holly's, otherwise the 9375 Holley 1050 works good
Re: sb stroker carb recommendations??? [Re: emarine01] #633395
03/08/10 01:02 PM
03/08/10 01:02 PM
las vegas
las vegas
guess that's tonight's project-let you guys know the outcome.
Re: sb stroker carb recommendations??? [Re: 70challenger408] #633396
03/08/10 02:53 PM
03/08/10 02:53 PM
AndyF Online content
AndyF  Online Content
I'm putting a Holley 650 main body on this 427 inch small block.
Re: sb stroker carb recommendations??? [Re: AndyF] #633397
03/08/10 05:55 PM
03/08/10 05:55 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I run my 1000cfm Holley (I said quickfuel before, but is a Holley with quickfuel E85 metering blocks) on my truck. Drive it every day...well when the streets aren't covered in snow anyway! I get the same 12mpg I got with the 750.
Re: sb stroker carb recommendations??? [Re: DconD100] #633398
03/08/10 09:50 PM
03/08/10 09:50 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Running a race demon rs with the 1050 sleeves in it and annular boosters on my 408. Going to try it with downlegs this year.
Re: sb stroker carb recommendations??? [Re: b1dartsport] #633399
03/10/10 06:07 PM
03/10/10 06:07 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
For the idle problem you might have a situation where the transfer slots are over exposed. Usually that can be fixed by cracking open the secondaries some which allows the primaries to be closed bringing the throttle plate to transfer slot relationship back where it should be. This usually happens with high duration cams.
Re: sb stroker carb recommendations??? [Re: 77DragracerR/T] #633400
03/10/10 11:39 PM
03/10/10 11:39 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
then don't buy a 959 from Biggs. Look at QFT.
Re: sb stroker carb recommendations??? [Re: JUST_N_TIME] #633401
03/11/10 08:26 AM
03/11/10 08:26 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I run Street Avenger 870s on them but with a little less cam. With your build Id say go with an HP950 if this is a strett car first and foremost.
