FEL PRO 8519PT Head Gasket Questions #633194
03/07/10 08:51 PM
03/07/10 08:51 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Does anyone have information on this head gasket,8519PT. I am needing the gasket crush thickness,bore,and CC.
Dan.
Re: FEL PRO 8519PT Head Gasket Questions [Re: mopar4ya] #633195
03/07/10 09:30 PM
03/07/10 09:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: FEL PRO 8519PT Head Gasket Questions [Re: stumpy] #633196
03/07/10 09:34 PM
03/07/10 09:34 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
http://search.store.yahoo.net/cgi-bin/ns...headgasket.html
???? Stumpy all I see there is a copper shim to be used with a 8519PT gasket.
Dan
Re: FEL PRO 8519PT Head Gasket Questions [Re: mopar4ya] #633197
03/07/10 09:36 PM
03/07/10 09:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sorry I read that as being the gasket. But I did find this. Felpro 8519PT-1 Head gasket, .039 compressed thickness. $42.68
Re: FEL PRO 8519PT Head Gasket Questions [Re: stumpy] #633198
03/07/10 09:40 PM
03/07/10 09:40 PM
Stuart, FL
Grassosgarage Offline
Stuart, FL
If I recall, this is the one that comes in the Fel Pro kit. I had this question too and wound up calling them and they said the compressed thickness is .039" just like the more expensive one.
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: FEL PRO 8519PT Head Gasket Questions [Re: Grassosgarage] #633199
03/07/10 09:50 PM
03/07/10 09:50 PM
NE
moparpoolman Offline
NE
What are you using them on? I had a problem with those on a 440 before, the bore size was too small to seal past the chamfer on the deck of the block.
Re: FEL PRO 8519PT Head Gasket Questions [Re: moparpoolman] #633200
03/07/10 09:54 PM
03/07/10 09:54 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Using them on a 440 that is .030 over with a flat top piston, KB237's with 0 deck height.
Dan.
Re: FEL PRO 8519PT Head Gasket Questions [Re: mopar4ya] #633201
03/07/10 10:03 PM
03/07/10 10:03 PM
NE
NE
They might not work, I had to use fel-pro FPP-1009's because of the chamfer on my block, just in case you don't know what that is it's the space between the bore and the deck of the block if the bore is not completely sqare to the deck.
Re: FEL PRO 8519PT Head Gasket Questions [Re: moparpoolman] #633202
03/07/10 10:12 PM
03/07/10 10:12 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks, I will have to lay a gasket on the block and see how it looks. Never gave that a thought to be a problem on a .030 over bore. I know the block has some chamfer, just have to check it out.
Dan.
