Need converter recommendations #633073
03/07/10 06:53 PM
03/07/10 06:53 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
I am working on a street motor, 383, 10:1, 484 cam, dual plane intake, 4.10 gears. what converter should i run?
not too up to speed on the automatics, but not looking to spend a lot...any help appreciated.
Re: Need converter recommendations [Re: Tommy383] #633074
03/07/10 06:57 PM
03/07/10 06:57 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
going in a duster....
is this a waste of money?
http://www.summitracing.com/parts/BMM-10416/
Re: Need converter recommendations [Re: Tommy383] #633075
03/07/10 06:59 PM
03/07/10 06:59 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I would contact Lane or Kenny at ptcrace.com They can build something that will work well and not cost a ton of $$$.
Re: Need converter recommendations [Re: Tommy383] #633076
03/07/10 07:45 PM
03/07/10 07:45 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
A good stock converter will flash to 2K so I think that is a waste of money
buy something a little better, or stick with a stocker, until you can afford to move up.
Re: Need converter recommendations [Re: dave571] #633077
03/07/10 09:28 PM
03/07/10 09:28 PM
Central NC
gch Offline
gch  Offline
Central NC
You get what you pay for with a converter.Cheap ones are.....well....CHEAP.
I would look into a 3500 stall 10" converter for what you have.
Take a chance on a used one if you know someone upgrading.
Re: Need converter recommendations [Re: Tommy383] #633078
03/07/10 09:49 PM
03/07/10 09:49 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
It seems people put a ton of money into their engines yet skimp on the converter. Putting a PTC 9.5" was the best thing I did for my Duster. It lowered my cruise RPM, and made driving and racing a heck of a lot more fun. If you're into bracket racing it also helped made my car very consistent.
Re: Need converter recommendations [Re: dustergirl340] #633079
03/07/10 11:39 PM
03/07/10 11:39 PM
with everyone above.......A bone stock number 764 Dacco converter will stall as high as 2,800 behind a stock 440 and they're extremely cheap.....Just get one at your local transmission supply house........If you need anything higher than that, call PTC and spend the $500.....you won't regret it.......
Wayne
Re: Need converter recommendations #633080
03/08/10 01:50 AM
03/08/10 01:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran that combo before as I had a 383 in a Dart. It had 9.5 comp with 452 heads and the MP .484 cam. We used 3.91's and we put a Turbo Action tight 10" 3000 converter in it which worked great. It was a street car that ran as fast as 12.31 @ 110. Ron
Re: Need converter recommendations [Re: 383man] #633081
03/08/10 01:58 AM
03/08/10 01:58 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Call Paul Forte at Turbo Action and see what he has to say. I'm still getting used to the power on the street I currently have.
