More pitman arm questions
#633012
03/07/10 06:06 PM
03/07/10 06:06 PM
Posts: 738 OK
David_Trimble
OK
Ok, I managed to get the nut off the pitman arm, and the arm is disconnected from the center link. So now's the 'fun' part - getting the arm pulled off the steering box shaft. I'm trying to get it off using a 2-arm gear puller but it's not budging so far. Would I be better of using something like this or has anyone managed to do it with a gear puller? Again- thanks! David
'69 Dodge Charger R/T
Re: More pitman arm questions
[Re: David_Trimble]
#633013
03/07/10 06:17 PM
03/07/10 06:17 PM
RapidRobert
Yes "that" is what you need and you might call your parts house & see if they have it to rent. It'd be cheaper for you as you rarely use it. Pitman arms get on there tight
[Re: stumpy]
#633016
03/07/10 06:37 PM
03/07/10 06:37 PM
Posts: 738 OK
David_Trimble
OK
Ok, thanks- I was able to pull the center link off with the gear puller but I figured with the splines on the pitman arm that it was going to require a LOT more force to get that off....
I'll ask the local parts stores to see if they rent specifically a pitman arm puller. I think the O'Reillys near me does rent- and if not I've got Advance and Autozone, too....
[Re: David_Trimble]
#633017
03/07/10 06:44 PM
03/07/10 06:44 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
why do you want to take it off? pitman arms are a no wear item...
I am truckless..
[Re: 340SHORTY]
#633018
03/07/10 06:51 PM
03/07/10 06:51 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Only on a chevy. On a mopar, The joint is in the pitman arm. The center link is the piece that doesn't wear on most mopars.
[Re: David_Trimble]
#633019
03/07/10 07:58 PM
03/07/10 07:58 PM
Posts: 671 Los Osos, Ca
CKessel
Los Osos, Ca
You might try and put some heat to it also. When it gets hot enough, it will expand some. Keep the puller on it when heating but be careful to stay out of the way when it comes off. You will not need too much tension on the puller during this time. Also watch out for other things that might cause you to have the hottest Mopar around[ gas leaks etc.] If you don't feel safe with the heat, you can also use an air hammer with the hammer type head to work on the sides of the arm when the puller is in place. Still be VERY careful as if its this stuck, it most likely will come off with quite a pop.
Carl Kessel
