Re: need holly help
[Re: 67mo-man]
#632865
03/07/10 12:36 PM
03/07/10 12:36 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
There is either dirt of some kind on needle and seat, or the adjustment is way off, you have a bad-sinking float, or you have too much fuel pressure. ![](/ubbthreads/images/graemlins/Twocents.gif) One of my holley red pumps had cosmoline type crud stuck in regulator out of the box and caused flooding many moons ago.
Re: need holly help
[Re: buildanother]
#632867
03/07/10 12:40 PM
03/07/10 12:40 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Fuel pump can be putting too much pressure to the needle/seat and causing fuel to flood the engine. Safe fuel pressure is 5-6 PSI... It is also possible the carb has always been bad, missing a gasket, or fuel level wrong from the factory... ![](/ubbthreads/images/graemlins/Twocents.gif)
