Re: torsion bars, What size do i need
[Re: mattpar]
#632603
03/07/10 01:50 AM
03/07/10 01:50 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
I'm finishing a T/A and i have .88 bars, should i get .92" bars or go to 1" what is a better ride? I only plan on regular road driving, no going wicked fast and doing stupid stuff. So out of the three give me your opinion.
The .92 will give you a softer, quieter, less harsh ride. But the 1" will give you better handling around corners, less lean, and better grip. There's almost always tradeoffs.
[Re: mattpar]
#632607
03/07/10 08:57 PM
03/07/10 08:57 PM
autoxcuda
So Cal
So it sounds like i need to get some 1" bars, now how about the right size front stabil bar? mine is a .88 now, should i find a .96 also. I bought the car as a basket case with some stuff missing. But it has the original motor and trans and all the thanks to BERRY WASHINGTON, but that is a long great story i should tell later.But the one, well one of the many other questions i have is, the fast ratio box, dosn''t have a pitman arm. what should i do about that. And last for today i would like some more opinions about the dash. Remember the car didn't come with the rallye dash so give more advice about making it into a ralley.
Is the .96 diameter front sway bar the special T/A-AAR only sway bar?
You are going to have to make a choice at some point if you want this to be a stock restoration or a restified (slightly modified) restoration.
I'd run a stock/HD E-body front sway bar and stock rear sway bar. The aftermarket ones stand out.
You could have www.redlinegaugeworks.com put a tach in your standard cluster too. IMHO those are easier to read than the Ralley tachs. He could make the speedo go to 150 mph too if you'd like. Plan on going to 150 mph in it?
Is the car coded for Fast Ratio power steering? It is an option I thought.
