Re: Newer style 904 converter with small snout
[Re: XXX440]
#632524
03/06/10 10:44 PM
03/06/10 10:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There is a third way, a later crankshaft.
Other than that, those are your options
[Re: XXX440]
#632525
03/06/10 10:58 PM
03/06/10 10:58 PM
RapidRobert
I'll defer to Kunkel for the final word on this but I believe that the later (larger) input shaft (reaction shaft maybe larger too?) required the larger TC "nose" so if that is correct then that'd leave one option left, if the earlier input and or reaction shaft(s)/pump will fit in the later trans or as said swap cranks which I dont think you want to do.
[Re: RapidRobert]
#632528
03/07/10 02:33 AM
03/07/10 02:33 AM
Posts: 20,214 Park Forest, IL
slantzilla
Park Forest, IL
Continental used to make a large spline/small snout stock stall converter for around $200. A few guys on the Slant board had them made.
