Re: Help installing piston rings
[Re: dhutch]
#632125
03/06/10 12:32 PM
03/06/10 12:32 PM
Posts: 7,506 Az
Crizila
Az
All dots up. If the beveled edge is on the opposite side of the dot, its the second ring. 90% sure on this, but I would still check with speed pro to be absolutely sure.
Fastest 300
[Re: Crizila]
#632126
03/06/10 01:08 PM
03/06/10 01:08 PM
Posts: 236 upstate, New York
jvcuda
upstate, New York
But, new heads,new cam,why not new rings too?
![](/ubbthreads/images/graemlins/drive.gif)
[Re: jvcuda]
#632127
03/06/10 01:11 PM
03/06/10 01:11 PM
Posts: 33,005 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Used rings strecthed three times ,once on,once off and then on again, is not a good idea. New rings are way cheaper then another complete tear down to fix a gouged cylinder. Plus the possible need of new pistons and rings to fit the new bored block if the gouge is deep enough.
Re: Help installing piston rings *DELETED*
[Re: dhutch]
#632128
03/06/10 01:13 PM
03/06/10 01:13 PM
340dart4spd
Parts Problem
Parts Problem
Post deleted by dhutch
What was it about??? guess we will never know?
