Re: Battery cable for trunk mount battery
[Re: Rodney]
#632095
03/06/10 11:05 AM
03/06/10 11:05 AM
Posts: 2,527 PA
moparacer
PA
I used #1 welding cable.
Never come close to stressing it out in a car the way you do when your welding.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 65superstock]
#632098
03/06/10 12:47 PM
03/06/10 12:47 PM
Posts: 554 Florida
65HemiCoronet
Marine grade cable is going to be the highest quality. I work in the marine electrical industry, and we use tinned copper cable. Best stuff for high current capacity. Welding cable is a good second choice, but be careful of the jacket around corners and sharp edges. It's not very abrasion resistant. Use some larger hose to slip over it, or they sell split loom for cable protection. Also, it may just my opinion, but I ran both positive and negative cables to the front, I did not use the body to carry negative current back to the battery. I don't believe that is the best route to take. Again, that is just my opinion.
Yeah, it's got a hemi........a REAL hemi.
[Re: 52savoy]
#632099
03/06/10 12:52 PM
03/06/10 12:52 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Welding cable is designed for an entirely different use. It works but is not correct. You can get #1 Automotive wire at NAPA and I used solder (sp) on ends. They have solder pills you put in the end and heat to melt then stick the wire in and let cool.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#632100
03/06/10 12:57 PM
03/06/10 12:57 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
NAPA has the solder pills?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Rodney]
#632102
03/06/10 05:32 PM
03/06/10 05:32 PM
Posts: 1,377 Ohio
Todd
Ohio
we buy the cable at our local auto parts store. We also borrow the cable crimp tool from them once we are ready to install the ends.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: DragDart360]
#632104
03/06/10 06:58 PM
03/06/10 06:58 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yeah, it's not correct.. It's serious overkill, It will never give you any problems, Battery cable is made slightly different because it was made for a different, but similar, application. Battery cable doesn't need to be as flexible because it stays in one spot for it's life. Welding cable is wound up in a coil every time it's not being used and also dragged around cement and tight corners. The rubber also protects it against rips and tares from its rough environment. Battery wires only have 19 strands of copper to make the awg size needed compared to the minimum of 300 strands for welding wire.
Even though a lot of wire and cables are very similar they have differences that need to be addressed. You can use the welding cable for a battery application but not the other way around. It is a much better cable with added flexibility which makes it more expensive.
[Re: 1_WILD_RT]
#632105
03/06/10 07:13 PM
03/06/10 07:13 PM
Posts: 213 Mountains of NM
65superstock
Mountains of NM
Actually, many of the ones I have looked at have 133 strand not 19. But I was curious as to what REAL differences there were in respect to the outer sheath. So nobody out there has used the Mad Electrical cable?? ![](/ubbthreads/images/graemlins/scope.gif) -Jason
