home made front motor plate is 1/8 steel strong enough #632075
03/06/10 10:30 AM
03/06/10 10:30 AM
michigan
sturmenater Offline OP
michigan
I made my own big block front motor plate I was thinking if the others where 1/4 aluminum that my 1/8 steel plate would work. I think thats what the mid plates are made of.
I was going to atempt to make the mid plate myself also but I figured for $65 i would just by that then I would not have the hassle of making the crank spacer.
Im not CHEAP just thrifty
Re: home made front motor plate is 1/8 steel strong eno [Re: sturmenater] #632076
03/06/10 10:39 AM
03/06/10 10:39 AM
The front motor plates are aluminum and I made mine out of 3/8
Re: home made front motor plate is 1/8 steel strong eno [Re: ] #632077
03/06/10 10:56 AM
03/06/10 10:56 AM
Roanoke Va
gearjammerdart Offline
Roanoke Va
I would think 1/8th steel would flex to much.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: home made front motor plate is 1/8 steel strong eno [Re: gearjammerdart] #632078
03/06/10 11:00 AM
03/06/10 11:00 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I think it would handle the torque, but you will definitely need for/aft locators/links to keep the engine/trans combo from moving forward or back. To stiffen it in the for/aft direction, you could add flanges to the edges to stiffen it up. I'd still want the locators/links.
Floyd Lippencott IV
Re: home made front motor plate is 1/8 steel strong eno [Re: gearjammerdart] #632079
03/06/10 11:01 AM
03/06/10 11:01 AM
Donald
Thats why steel is not used.
I have since angled the tops
Re: home made front motor plate is 1/8 steel strong enough [Re: sturmenater] #632080
03/06/10 11:14 AM
03/06/10 11:14 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I've got a motor plate(elephant ears) made out of 1/8" steel and didn't have any problems at all. It was in the car over 10 years. I still have them and I'm considering them for another car.
Re: home made front motor plate is 1/8 steel strong eno [Re: mr_340] #632081
03/06/10 11:54 AM
03/06/10 11:54 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Fore and aft is an issue even with 1/4" aluminum and will be more of a concern with 1/8" steel.
A 1 piece motor plate is the way to go. The elephant ear style has a lot less torsional support and can create havoc on water pump gasket sealing.
If you need a steel mid plate send me a PM I have a New Never Installed one with the crank spacer I'd part with.
Re: home made front motor plate is 1/8 steel strong eno [Re: roadhazard] #632082
03/06/10 12:19 PM
03/06/10 12:19 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
I am running an 1/8" steel elephant ears set up that I built when the car was still a street car back in the late 80's. It has a rubber mount on each side between the frame and the elephant ear due to it being for a street car and also have a rubber tranny mount. I know this is less than ideal, but the car has gone from being a high 12 second street car to running as fast as 10.30's in vegas and I still use the same setup. I took care of the water pump gasket issue by dropping the gaskets and just using a good gasket sealer. I know I should change it and I will the next time the motor comes out. I like the looks of AndyF's engine plate and will probably use it.
Re: home made front motor plate is 1/8 steel strong eno [Re: dragnduster] #632083
03/07/10 08:49 PM
03/07/10 08:49 PM
michigan
michigan
I have another question I thought i would drag my old post up instead of making a new one.
Do any of you mont your ignition box on the front motor plate or is there to much vibration?
Im using a mallory hyfire and thought it would look alot cleaner wire wise if it was up front by the distributor
Re: home made front motor plate is 1/8 steel strong eno [Re: sturmenater] #632084
03/07/10 09:08 PM
03/07/10 09:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nothings cleaner than under the dash in my opinion.
