Page 3 of 6 1 2 3 4 5 6
Re: New Edelbrock Carb Issues. [Re: TimS] #631978
03/10/10 08:33 AM
03/10/10 08:33 AM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
I went through two Holleys on a 360, before I found a good Carter. Loved it so much I picked up a second as a spare.
Had issues with my 750 AFB (edelbrock) on my 440, until I got the 'strip kit' and tuned it properly, with the help of an LM-1 O2 meter. Then it was great!
With my 505, I had to go Holley, and went with a Dominator.
After getting some Quickfuel metering plates, that Holley has been one of the best carbs I've owned.
Long story short: I'm a big fan of the AFB carbs, but have finally 'discovered' Holley.
I would tend to agree with most of what's been posted. I'd put a AFB on a 'street' car, and a Holley on something for the strip.
Cheers!
Re: New Edelbrock Carb Issues. [Re: Damned67] #631979
03/10/10 01:43 PM
03/10/10 01:43 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I would agree with that. I'm not a drag racer so that's why the Carter/Edel combo has worked for me on my street cars. Friends of mine with big Holleys are also always complaining about fouled plugs and rough running cars. Wrong size carb for the applications any, I suspect.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: New Edelbrock Carb Issues. [Re: TimS] #631980
03/10/10 01:58 PM
03/10/10 01:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
they need to tune on them some more. Any carb will fol plugs or run lean if it's not tuned.
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631981
03/12/10 07:35 AM
03/12/10 07:35 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
That's true but it could also be just a matter of wrong carb for the application.
Re: New Edelbrock Carb Issues. [Re: TimS] #631982
03/12/10 08:13 AM
03/12/10 08:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could be but I ran a 750HP mechanical carb on a very mild 340 and it didn't foul any plugs, run rich, and got the same mpg as the 625 carter that was on the car when I bought it.
Re: New Edelbrock Carb Issues. [Re: Mr.Yuck] #631983
03/12/10 09:22 AM
03/12/10 09:22 AM
scratchnfotraction Offline
race = Holley gas holes
mild street = carterbrock
gas milage = Q-jet/thermobog
runwhatyabrung
Re: New Edelbrock Carb Issues. [Re: scratchnfotraction] #631984
03/12/10 10:53 AM
03/12/10 10:53 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
I will post that link a second time - READ IT READ IT - There are good links within links
How come the Edelbrock 750 , I REPEAT EDELBROCK 750 - 1407/1411 , NOT THE 800 NOT 600 NOT , is the most talked about Carb on this Website , and its mostly 99% Negative/Issues ???
And i dont care what you throw at it internally - Its nothing more then a P.O.S. Expensive Paperweight
I love these Quotes - Straight from the Moparts Tech Archives/Dyno 383 - Go ahead and look them up yourself - All the Dyno #s and info right here on this site
"All the aftermarket carbs tested ran fine with the stock calibration except one...the Edelbrock 750, #1407. this one ran very poorly.....it didnt really do anything well. it was just flat out lean everywhere. idle, part throttle cruise, WOT...and it didnt like to take a load at all. when getting ready to start a pull and going to full power, the motor would fall right on its face, then try to recover....finally recover, and then you could start the pull.
i found this to be pretty interesting because i also had on hand a Carter AFB 750 manual choke version which ran perfectly fine everywhere.
decent throttle response, good part throttle cruise A/F ratios, decent idle A/F ratio with the mixture screws out only 2 turns, and the WOT A/F ratio was right where it should be, and it had a pretty flat fuel curve as well.
i was running short on time, so i just continued on my testing of other things. when i was done for the night i pulled apart the Ebrock carb to see if someone had recalibrated it. this is not a new carb, but was pulled from my friends 396 Chevy yesterday morning. he's been running on the street, and didnt really indicate there was any kinds of problems with it, but there was an indication that another friend of his may have changed some jets or something.
well....that was not the case. it had all the stock jets, rods, and springs, and had no dirt or debris inside. the calibration was just that far off from ALL the other aftermarket carbs.
IMO, the Ebrock carbs are set up for motors that are much milder than what most people are building. well, most people i know anyway
anyway....back to the trenches....."
"The only carb that didnt actually run well was the Ebrock carb. it just didnt do anything well. poor idle, too lean everywhere, didnt take a load well, etc.
when i had a chance, i pulled it apart to see if there was any dirt or debris inside, and it was nice and clean. i also verified the calibration.
it was calibrated to the specs in the catalog."
"One final note....
i dont have anything against Ebrock carbs. it seems some here have a hard time grasping that it didnt run well. trust me...it didnt run well. its that simple. its not hard to tell if its good or bad when youve already made nearly 70 pulls on the motor before installing this carb.
yes, the problems it had could be tuned out of it. thats obvious since the Carter 750, which is the same thing ran just fine.
it ran how it ran...which wasnt good.
this is one of those "dont shoot the messenger" situations."
Enjoy all the Numbers / Quotes - Actually a great Arcticle on a whole bunch of Carbs - Click on Links
http://www.moparts.org/Tech/Archive/bb/25.html
http://www.moparts.org/Tech/Archive/bb/26.html
PEACE - Scott
I will add this - The Main Difference between the Edelbrock 750 and that Carter AFB 750 has alot more to doo with Internal Fuel Metering/Internal Airflow then just changing Jets and Metering Rods - And i dont care if there both made by Weber - You can take that to the Bank - Again read those LINKS
Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: New Edelbrock Carb Issues. [Re: bee1971] #631985
03/12/10 01:14 PM
03/12/10 01:14 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Regarding the origInal post a 750 edelbrock out of the box is way overkill for a 383 unless it's a really hot engine.
I disagree with this...I ran a Holley 750 VS on a near stock 383 and i know it flows more than an Eddy 750. Car ran great...never had any problems.
Have to laugh when I see these reality shows that have Edelbrock as a sponsor and they throw one of their carbs on a motor...you just know the builders want to put on a Holley/Proform/Quickfuel to make real power.
Re: New Edelbrock Carb Issues. [Re: bee1971] #631986
03/12/10 04:33 PM
03/12/10 04:33 PM
NL
Frederick Offline
Frederick  Offline
NL
The idle channel restriction needs to be reamed on the Edelbrock 750's to cure the bog.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: New Edelbrock Carb Issues. [Re: Frederick] #631987
03/12/10 06:50 PM
03/12/10 06:50 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
99% of tuning and drivability issues ("off idle bog") can occur with a single plane manifold with a modern dual plane hi rise intake manifold you can have better drivability...
Re: New Edelbrock Carb Issues. [Re: scratchnfotraction] #631988
03/12/10 06:58 PM
03/12/10 06:58 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
While I like each of these carbs for different purposes, I ALWAYS can get better mileage with a holley!!!
The sole issue I ussually have with a holley on a street carb is in the choke!!
Re: New Edelbrock Carb Issues. [Re: fox] #631989
03/12/10 07:20 PM
03/12/10 07:20 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I run the 1407 manual choke 750cfm Edelbrock carb on my mildly built 360 Duster and it runs great. Fattened the primary rods alittle to lean it out, adjusted the mixture screws and bumped the intial timing up to 18 degrees.
Smokes the tires out of the hole anytime with NO BOG and drop the hammer at any speed with NO BOG! Gas mileage? who cares!
The float setting MUST be checked on even new carbs and fuel pressure is also critical like people have mentioned. I'll bet many times people blame hesitation on the carb when it's actually the timing or distributor that is the culprit.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: New Edelbrock Carb Issues. [Re: MY340] #631990
03/12/10 07:50 PM
03/12/10 07:50 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I agree.. The edelbrock carbs tend to want a lot (more) of initial spark advance at idle.
You need to recurve your distributor mechanical advance curve, especially if you have a larger than stock cam in the motor. More initial at idle+ less mechanical advance travel +34-36deg total timing at high rpm WOT.
Re: New Edelbrock Carb Issues. [Re: STROKIE] #631991
03/12/10 08:08 PM
03/12/10 08:08 PM
dont blame the carb, its the person tuning the carb.
heres 2 edelbrocks that run awesome.you just got to get inside them and tune to your specs.
Re: New Edelbrock Carb Issues. #631992
03/12/10 09:19 PM
03/12/10 09:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have been running the same Edelbrock 1407 for over 20 years. From a 413 to 360 to 318 to a 225.
Worked fine for me, had to tune it a bit for each engine combo. On the 318 I got low 20's for mileage, a 1406 would get me mid 20's, both highway. The 360 was a bit lower, the 413 lower still, the 225 was a lark, never checked mileage, I had a 4bbl intake so I had to run it at least once just to see.
That said, and I have made this offer before with ZERO takers, I will buy your POS Edelbrock carb's at $25 a pop.
I expect to, once again, have zero takers.
Don't be the exception.
Re: New Edelbrock Carb Issues. [Re: Supercuda] #631993
03/12/10 10:47 PM
03/12/10 10:47 PM
i got one you can have for 25$
what the addy you want it sent to?
Re: New Edelbrock Carb Issues. [Re: scratchnfotraction] #631994
03/12/10 11:15 PM
03/12/10 11:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
YOu have a PM
Re: New Edelbrock Carb Issues. [Re: Supercuda] #631995
03/13/10 01:37 AM
03/13/10 01:37 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
You can't swing a cat on this board without a 750 Eddy post.
I think you will see a power gain with a 750 Holley or 800 AVS. Or a 750 Carter.
The small Eddys work good, but 383 will like more carb.
I currently have a 650 Carter on my 383 HP. Not bad, I can tell it is down on power from the 750 Eddy mid range that it replaced. Carter- A much better carb though all around.
I have a 750 DP that I tired last summer as well but it must have a dirt clod in it someplace as it idled well for a few minutes and then quit. I would like to be able to report a back-to-back for the board at some point.
Would really like to swap the DP for a 3310 vac. I had one of those that rocked the house. I do like the Carter style carb for a dailey use car. Wouldn't mind a 800 AVS either.
I want my fair share
Re: New Edelbrock Carb Issues. #631996
03/13/10 01:20 PM
03/13/10 01:20 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thats Funny - The Person HA HA HA HA
Hopefully Those Are not 1407s on that Awesome Ride ???
Seriously , Nice Car
But Back to the Subject
Guys that Love There 1407s/1411s dont realize how much Performance there leaving on the Table until they Actually Swap To a Holley or a Edelbrock 800 Series
I Found This arcticle the other day - Read it
The Edelbrock 800 is good for at least 2/10s-3/10s in the 1/4 over a well tuned 1407
And Thats excactly what i noticed on my 71 Superbee when i did the Swap - And my Edelbrock 800 was box stock other then me Changing Metering Rod Springs
And to those who say a 750-800cfm Edelbrock carb is overkill on a 383 , Think Again
Well the 750 is overkill - As in it KILLED MY PERFORMANCE - By the way those Chevy Guys love those P.O.S. 1407s on Ebay
Edelbrock 800 is an Awesome Carb ! - Why Anyone would waste there money on a 1407/1411 is beyond me
READ THIS NOW !!!!!!!!!!!!!AWESOME ARCTICLE
Third Page has the #s/Times
http://www.moparmusclemagazine.com/techa...test/index.html
Siberian Huskies
Re: New Edelbrock Carb Issues. [Re: bee1971] #631997
03/13/10 01:27 PM
03/13/10 01:27 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I Give You Guys Dyno #s and now 1/4 Mile #s
And Watch , Some will still come on here and say the 1407/1411 is Still The Greatest Thing Since
EPS750 Vs. EPS800 Carburetor & Intake Test - Edelbrock EPS Carburetors: Worth The Time!
EPS 750 vs EPS 800 Comparison
Baseline: 750 Edelbrock Performer, rpm intake; metering rods-.071x.047; jets: .110 primary, .107 secondary. Weather: 97 degrees F., 60 percent humidity, 29.94 barometer. Additional changes: Hoosier slicks 26 x 9
RUN 60 Foot 1⁄8 mile 1⁄4 mile mph notes
1 1.89 8.53 13.68 97.62 after one hour cooldown
2 1.90 8.62 13.79 96.98 hot lap
3 1.89 8.58 13.77 97.23 half-hour cooldown
Test: 800 Edelbrock Performer, rpm intake; metering rods-.071x.047; jets: .113 primary, .107 secondary. Weather: 98 degrees F., 54 percent humidity, 29.94 barometer. Additional changes: Hoosier slicks 26 x 9
Run 60 Foot 1/8 Mile 1/4 Mile MPH Notes
1 1.86 8.40 13.44 99.89 after one hour cooldown
2 1.87 8.46 13.53 99.21 hot lap
3 1.87 8.44 13.48 99.47 half-hour cool down
Siberian Huskies
