440 engine - question you may laugh at.
#631456
03/05/10 03:54 PM
03/05/10 03:54 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
Feel free to point and laugh, but how do I set the valve lash on the mopar factory rockers? I'm new to chryslers. They don’t have any adjustment points from what I remember seeing last. Is it all managed by the pushrod length and hydraulic lifter? I know you can shim the shaff assembly if needed but that’s not what I have to do. I know the general procedure for adjusting the valves, just confused on the adjuster that actually controls that adjustment. I am just trying to set the lash for the initial fire up. Thanks for the help, sorry for the lame question.
Re: 440 engine - question you may laugh at.
[Re: HitIt]
#631457
03/05/10 04:03 PM
03/05/10 04:03 PM
Posts: 15,487 Florida
scratchnfotraction
non adjustable rockers on a stock head the lifter does the lash with the soild PR if you had adjustable rockers you would have a bolt and jamb nut on the rocke to adjust your over-thinking it for fire up...just prime the oil pump with a drill and turn the engine over by hand a few times while the drill is pumping oil when you get oil to the rockers,your set for start up side note...they will clatter some till fully pumped up on start up but should stop clattering and quite down I pull the plugs and spin it in short burst with the starter to get it primed also
