Re: another front disc swap ??
[Re: Stanton]
#630877
03/09/10 01:20 PM
03/09/10 01:20 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
... I like the idea of mounting them from the rear - will allow the use of my stock swaybar.
If you do that, be very careful re: hose routing. Generally, you want the hose to cross the steering axis, which your idea prevents, unless you move the hose frame bracket.
Be sure the hose doesn't rub or go taut, esp. at full L/R lock and full jounce and rebound travel, and all combinations thereof.
A failed hose is not fun.
Rick
[Re: DoctorDiff]
#630882
03/09/10 09:07 PM
03/09/10 09:07 PM
Posts: 1,301 Edgartown, MA/ Greene, ME
CharlieB
I used the A Body spindels, Cordoba calipers, rotors with the Volare hoses on my 69 SBee- has worked just fine for the last 4 years, 30,000 miles
