another front disc swap ?? #630870
03/05/10 12:15 AM
03/05/10 12:15 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Ok, doing a disc swap per the Mopar Action article and I'm stumped on the calipers. I've been on the RockAuto, Advance Auto Parts and Autozone websites and none of their calipers look like the "4" or "5" calipers in the attached photo. I'm looking at calipers from a '76 Cordoba. The hose mounts are different and apparently that's critical.
Also, in the article it gives aftermarket part numbers EIS RC6066/65. Who the hell is "EIS" ?
The article doesn't seem to specifically tell which model to get the calipers off of so I'm stumped.
Thanks!
Re: another front disc swap ?? [Re: Stanton] #630871
03/05/10 12:28 AM
03/05/10 12:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Try calipers & hoses for a 70-74 B or E body... EIS was a major manufacturer of brake components originally they owned Parker Hannifin which became such a giant company that they eventually sold the parent company EIS to Standard Motor Products...
Re: another front disc swap ?? [Re: Stanton] #630872
03/05/10 12:49 AM
03/05/10 12:49 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I like to use the Cordoba caliper, mounted toward the rear with a pair of 15" DOT stainless flex hoses.
Re: another front disc swap ?? [Re: DoctorDiff] #630873
03/05/10 07:48 AM
03/05/10 07:48 AM
BDW Offline
BDW  Offline
Here's the parts list I used when converting to the 11.75 sliders.
I bought eveything for my Challenger at local Advanced Auto. If you order online, you'll get free shipping.
raybestos w/pad RC4103/4 $36.00
78 charger (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorfman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
Re: another front disc swap ?? [Re: BDW] #630874
03/05/10 09:20 AM
03/05/10 09:20 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
What spindles are needed for the swap?
Re: another front disc swap ?? [Re: DoctorDiff] #630875
03/05/10 11:10 AM
03/05/10 11:10 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Dr. Diff ... I like the idea of mounting them from the rear - will allow the use of my stock swaybar. Where would I get the hoses you mention - are they an "off the shelf" item?
1 WILD RT ... The '70-74 B/E-body calipers are the one's in Ehrenberg's photo - Thanks!
I'm planning to use the "pin" style calipers.
Re: another front disc swap ?? [Re: Stanton] #630876
03/05/10 07:28 PM
03/05/10 07:28 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
bump
Re: another front disc swap ?? [Re: Stanton] #630877
03/09/10 01:20 PM
03/09/10 01:20 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
If you do that, be very careful re: hose routing. Generally, you want the hose to cross the steering axis, which your idea prevents, unless you move the hose frame bracket.
Be sure the hose doesn't rub or go taut, esp. at full L/R lock and full jounce and rebound travel, and all combinations thereof.
A failed hose is not fun.
Rick
Re: another front disc swap ?? [Re: Stanton] #630878
03/09/10 04:14 PM
03/09/10 04:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock a custom DOT stainless flex hose kit for rear mounted calipers. The hoses are coated in clear plastic with whip stops around the ends.
They do not rub if installed correctly.
Re: another front disc swap ?? [Re: Stanton] #630879
03/09/10 05:07 PM
03/09/10 05:07 PM
AndyF Offline
AndyF  Offline
I'm not aware of a model of the pin type calipers that works properly when rear hung. There is a version of the slider calipers that is designed to be rear hung. The rear hung pin type calipers that I'm aware of all used a hard line to the front of the suspension so the brake hose could cross over in a straight line.
Re: another front disc swap ?? [Re: AndyF] #630880
03/09/10 06:35 PM
03/09/10 06:35 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'76 Cordoba pin calipers can be rear hung. The line port is in the same area as a 1980 Volare' slider caliper.
Re: another front disc swap ?? [Re: Stanton] #630881
03/09/10 08:32 PM
03/09/10 08:32 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Where would we be if we didn't try new things ...
While the responses here are from reputable sources, I'm inclined to try Dr. Diff's lines IF he states here that they will work on a '69 B-body with the frame mounts in the stock location.
So far the swap has/will be simple enough but having to mess around with the swaybar is more than I want to tackle. My k-member doesn't have the notches for a '70 bar and swapping in a '70 k-member and bar are not expenses I want if a set of specialized brake hoses solves the problem.
Whatdya say Dr. Diff ... your lines do a b-body with the stock bracket locations?
Re: another front disc swap ?? [Re: DoctorDiff] #630882
03/09/10 09:07 PM
03/09/10 09:07 PM
Edgartown, MA/ Greene, ME
CharlieB Offline
CharlieB  Offline
I used the A Body spindels, Cordoba calipers, rotors with the Volare hoses on my 69 SBee- has worked just fine for the last 4 years, 30,000 miles
