Re: Throttle stop and using a 3 speed?
[Re: 70RTRacer]
#630500
03/04/10 05:01 PM
03/04/10 05:01 PM
Posts: 10,082 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have messed around with a throttle controller, which I believe will be less violent when coming off the delay time. Probably want to shift gears on a timer, get it into high, then let the stop go to work. A high powered motor coming back on in any gear but high could cause trouble.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: 70RTRacer]
#630502
03/05/10 11:03 AM
03/05/10 11:03 AM
gregsdart
Can't recall the initials exactly, "BCR"? It is a dual stage controller, which allows one setting for the launch, and one for down track. I found the launch rpm to be a big factor in getting my car to leave with a TF. Wide open off the stop it has too much torque multiplication, at least it did for my car. One other thing, I run a terminter on alky, and found the adjustment being too course. You have to rotate the throttle shaft one full thread to adjust, which is way more than I would like. Some home engineering should come up with a good solution to this issue. If you are going to be serious about "stop" racing, I think that will be very important in getting the exact rpm you need at launch.
Post deleted by Defbob
[Re: Al_Alguire]
#630504
03/05/10 11:23 AM
03/05/10 11:23 AM
#630505
03/05/10 12:36 PM
03/05/10 12:36 PM
Posts: 331 O'Fallon,IL.
70RTRacer
O'Fallon,IL.
Thanks again Greg. Al, I hear you on the glide. If I didn't have a mint in my TF, convertors, shifter and drive shaft I would have a glide in it. I am thinking about a new combo for next year. Maybe a Predetor motor and a glide. But for this year I thought I would try some of the super classes. You look like you are having fun with it. Fred, if I had the $$$$ I would be in a ProMod. That is what I would call racing.
[Re: StripeHOG]
#630508
03/05/10 04:17 PM
03/05/10 04:17 PM
Posts: 12,298 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Many higher horsepower .90 racers use timers to both shift and go on the stop at around the same time, usually very early in the run. The combination of when the shift and the stop coming on, in relation to each other, occurs has a big effect on consistency. The same thing could be done with your 3 speed. All you need to do is get it into high gear somehow (timer, RPM). I did this years ago before going to a 2 speed. I was in 2nd and on the stop before 60'. Used a RPM triggered shift light for high. Worked very well then, they are a little touchy about flashing lights in the cockpit these days.
[Re: CMcAllister]
#630509
03/06/10 09:46 PM
03/06/10 09:46 PM
Posts: 1,622 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, i run super gas with 727. have done very well. i go on the stop .05 stay on for about 1.5 sec. then shifts into second gear i think i have the only super gas car in div 1 with 727!!! gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#630510
03/06/10 09:56 PM
03/06/10 09:56 PM
Posts: 5,025 new jersey usa
11secdart
new jersey usa
A friend of mine I haven`t seen in awhile ran Super/Gas with a Small Block Daytona and a 904 and did pretty well but eventually he went to a Glide. I know because I bought one of his 8 inch 904 converters when he switched.
