Any info on angle milling heads??? #629606
03/03/10 12:36 PM
03/03/10 12:36 PM
Hershey,PA
mracer360 Offline OP
Hershey,PA
I don't know much about angle milling cylinder heads. Does anyone know of a site or article that I could get more information on this process? Anyone have any results vs. traditional milling? Thanks-Mackey
Re: Any info on angle milling heads??? [Re: mracer360] #629607
03/03/10 12:52 PM
03/03/10 12:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
What do you have SB or BB? What type of heads?
Re: Any info on angle milling heads??? [Re: mracer360] #629608
03/03/10 12:59 PM
03/03/10 12:59 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: Any info on angle milling heads??? [Re: roadhazard] #629609
03/03/10 02:11 PM
03/03/10 02:11 PM
Hershey,PA
Hershey,PA
SB/Edelbrock
Re: Any info on angle milling heads??? [Re: RemCharger] #629610
03/03/10 02:12 PM
03/03/10 02:12 PM
Hershey,PA
Hershey,PA
Everything we do is $$$$$
Re: Any info on angle milling heads??? [Re: mracer360] #629611
03/03/10 02:25 PM
03/03/10 02:25 PM
Hershey,PA
Hershey,PA
Re: Any info on angle milling heads??? [Re: mracer360] #629612
03/03/10 04:41 PM
03/03/10 04:41 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i believe victorylibrary.com has this info in the tech page for mopars.
Re: Any info on angle milling heads??? [Re: mracer360] #629613
03/03/10 07:27 PM
03/03/10 07:27 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
SB/Edelbrock
IMO with the heads available for our engines Angle milling is obsolete. I see no use for any of the extra work thats required. Its a Trick thing of the past. Just my mike
Re: Any info on angle milling heads??? [Re: Sport440] #629614
03/03/10 09:40 PM
03/03/10 09:40 PM
dulcich Offline
dulcich  Offline
I wouldn't angle mill unless you are a guy with lots of time and can do machine work yourself, and you like to fool around with stuff. Angle milling was primarily a Chevy thing, because the 23-degree heads make the chamber really deep. This was about the only way to pull the volume down for compression, especially on some of the older, smaller engine combinations, like a 301 small block combo. Mopars, with the shallower valve angle and round open chambers really don't need to be angle milled. In fact they need to be flat milled, if we are dealing with typical OEM open chamber heads, and trying to take them to the max. By the time it is flat milled to a closed chamber, you are already pushing it, so angle milling on these heads is a complete non-starter.
If you read all that and decide that you want to angle mill anyway, now your manifold angle is off and needs correction, and pushrod holes are off and may need correction too. Your head bolts holes will also meet the block at an angle and you can get busy correcting the spot-face on the bolt holes and clearance the holes top and bottom for the angle. Hope this gives you all the info you need on angle milling.
-dulcich
Re: Any info on angle milling heads??? [Re: dulcich] #629615
03/03/10 11:24 PM
03/03/10 11:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2
It's not broke - don't fix it.
Boffin Emeritus
